Oil in the intercooler?
Old Jun 19, 2007 | 11:34 AM
Dustball8504's Avatar
Dustball8504
Ok, I'm new to the 6.0 and actually know nothing. However, yesterday I was installing a Banks High Ram on my 04 F250PSD and when I pulled off the driver side intercooler tube I noticed there was oil laying in it and what appeared to be a few small metal shavings. Can anyone tell me what might be going on with this one? Thanks!!!
Old Jun 19, 2007 | 11:37 AM
dayooper's Avatar
dayooper
sounds like you got some turbo wash going on. Oil is from the turbo and the shavings from the vains (worse case) but it makes sence to me. Have you been running an aftermarket airfilter?
Old Jun 19, 2007 | 11:40 AM
Dustball8504
I actually just installed the Banks ram air kit at the same time. It still had the factory air filter in it.
Old Jun 19, 2007 | 12:05 PM
dayooper's Avatar
dayooper
check you turbo to see how much play is in the vains. how many miles are on the truck
Old Jun 19, 2007 | 12:17 PM
Dustball8504
34,000. I'll check it out though, I've only had it for 2 weeks.
Old Jun 19, 2007 | 04:03 PM
blackhat620's Avatar
blackhat620
Oil in the CAC tubes is normal. The crankcase is vented into the air intake just ahead of the turbo. Only way to prevent oil in the CAC tubes is to re-route the crankcase vent tube. This mod is in the tech folder.
And lose the A/M air intake, they are a bad deal on the 6.0 and will cause warranty issues with FMC
Old Jun 19, 2007 | 05:44 PM
Dustball8504
Thanks for your help everyone!
Old Jul 5, 2007 | 05:17 AM
Gervis's Avatar
Gervis
Yup, I agree... It is normal and it is ok up to a point. Your valve breather and PCV valve hoses are usually routed back into the intake piping. Then the oil goes throught the turbo, then IC then gets burned. The problem is, that some of that oil builds up inside the intake piping, compressor and finally intercooler. So it builds up and builds up, attracks dust and dirt and finally you have a clogged IC. Not good at all. IC efficiency goes down. What I recommend doing is getting an oil catch can/breather valve (in my GMC case I usually use a GMC air filter recharge kit which is usually has the cleaning compound found in a oil catch can) to avoid sending the oil into the intake if you are not comfortable with the mod of re-routing the crankcase vent tube. Good luck!!!
deano-was-his-name-o
Jul 22, 2012 11:00 AM
Yahiko
Jul 12, 2012 04:17 AM
crazymut
Dec 19, 2009 07:19 PM
Ford79
Apr 28, 2007 08:22 AM
44magnum
13
Jul 27, 2006 08:51 AM
