6.0 wouldn't start
Old Jun 19, 2007 | 08:17 AM
Bulldog_shotgun's Avatar
Bulldog_shotgun
6.0 wouldn't start
i came home last night in a hurry and didn't let my turbo cool down like i usually do. (stock motor, wasn't driving that hard, EGT shouldn't have been to high)
anyway 5 mins later i went back outside to leave and it wouldn't start. it wouldn't even fire. i tried cranking it 10-20 times over the space of a half hour. it never fired once. no smoke, nothing. the fuel pump was running and i checked all the fluids, everything was fine. finally after an hour of messing with it i got mad and gave it just a wiff of ether. which got it to fire and then start. it has restarted since then 5-6 times with no problem. but it kinda bothers me. i don't want to be stranded. its still under warranty but if i can't get it to do it again how will the dealer be able to diagnose it?
anybody have any ideas?
by the way the tach never moved, but i'm not sure it ever does.
can anybody recomend a good dealer in the dayton, ohio area????
Old Jun 19, 2007 | 10:39 AM
hott-rodd's Avatar
hott-rodd
Check your oil.
When was the last oil change?
Do a search on HPOP.
Old Jun 19, 2007 | 10:46 AM
tttario's Avatar
tttario
HPOP is loosing its seal. I had the same problem with my truck 2 months ago. Except I couldn't get it started again. It will not deliver fuel if the pressure is less than 500 psi. You must have shocked it when you gave it the ether. I know it is running now but it will do this again if you don't bring it in. There is a TSB for the Diesel techs to replace the o-ring and install a mounting bracket that will eliminate the vibration that the HPOP recieves.
Cheers!
Old Jun 19, 2007 | 11:57 AM
IHbase's Avatar
IHbase
10-20 times? Seriously? And what do you suppose a "whiff" of ether will do if/when it hits glowplugs in cycle?
Listen to ttario. And knock off the ether stunt or you will be hurting.
-Mike
Old Jun 19, 2007 | 01:11 PM
msgtg's Avatar
msgtg
I think I remember reading somewhere that ether and diesels are a BAD mix.
Sounds like it needs to get to the shop especially since it's still under warranty.
Come to think of it....they're liable to tell you the ether is gonna cause you warranty problems.
Old Jun 19, 2007 | 01:20 PM
a-rod's Avatar
a-rod
HPOP or a leak in the system would be my guess as well. Usually they wont start when there hot, but once it cools all the way down it will. So thats probly what happend. THe ether might not have even been what started it.
Old Jun 19, 2007 | 01:27 PM
Bulldog_shotgun
thanks for the reply's guys.
its getting the HPOP bracket next monday morning. by the way ford flat rate is 8 hrs on that job. i bet thats a money maker for an experienced tech.
srpservices
Sep 12, 2013 09:03 AM
Excurvelle
Jun 25, 2012 09:12 AM
2020
May 13, 2010 11:12 AM
misnomer
Nov 30, 2007 04:33 AM
bbdano
Apr 11, 2007 07:01 AM
