I am putting a 3" body lift on my 04 f-150. can anyone tell me the largest tire I can put on there without cutting anything, or at least very small fabrication?
You should be able to fit 35s with a leveling kit, so if you put a $80 Auto spring leveling kit plus your 3" body lift you could fit somthing alittle bigger than 35s, but I'm not exactally sure(37s should fit).
I can't believe you said that. I can understand suggesting to keep the stock size, but saying that.....
Your truck came with about 30" tires stock, there's no way you could of kept it like that, huh?
