When the truck is cold everything is right with the world. However, on a hot afternoon, (95+, hey I'm in Southern AZ) After the truck gets warmed up the tranny temps start to get around the 170-180 mark (not towing) and the EGTs are running around 600. Both seem to be higher than normal, and the tranny sounds to be running at a higher pitch. Sometimes on the hiway it sounds like the tranny is "hunting" for the right gear (cruise on, level hiway).
At 67 the RPMS are still right at 2000, no varying on them at all If I turn the OD off and wind it up to 50 or so and then turn the OD on the tranny sounds like it always did ( a low sound). I'm think TC not locking up...??
If your TC isn't locking up, you'd see the rpms rise and fall with acceleration or deceleration. As far as hunting, this may be off base, but check your battery cables- if you're cable are corroded and you're getting intermittent valtage to the PCM, that may make it run screwy. AT least, that's what my tranny guy told me when I dropped 3 grand to have mine rebuilt at 160k.
Unfortunately for us PSD owners, the tranny effectively isn't built to the task of handling that much torque. There may be a few trannys out there at 200k or so, but I do know alot die between 110-150k miles.
Thanks for the reply, I'll check out the cables tommorrow. I recently changed out the batteries, so I'll double check the cables . However, the cable idea poses another question. If the cables are loose, bad, etc, wouldn't the "hunting" be all the time not when everything gets warm?
I'll let you know if I find out anything on the cables. At least I got SOMEONE to finally reply to a question I posted on the forum.
You got me there buddy- I didn't think mine were loose, but they were corroded enough to cause intermittent power to the PCM. This I would say is probably not the issue, but it's a thing worth looking at. I hate tranny issues!!
Well checked all the cables for any sign of corrosion but didn't find any (after all it is a AZ truck). Only thing I found that might be giving me problems was the small wire from the gas pedal area that goes to the tranny. It was caked with mud so I took it off and cleaned it up. Unforntunately, today still had the same problem. Any other ideas??
It sounds like your engine cooling fan is running because it needs to cool the engine. If the engine RPM does not change then the trans is not shifting or unlocking the torque converter.
There's nothing wrong here, so don't fix anything.
Thanks for the idea of the cooling fan. Just that this summer is the first time its done this and I've had the truck in AZ for the last 5 summers and I'm doing more hiway driving than in the past so I figured it would be getting more air, Do you think aux cooling fans would be worth it?
