Newbee cab removal
Old Jun 24, 2007 | 02:18 PM
jareddill's Avatar
jareddill
never mind, the cab, fenders, radiator support, grill, and all are sitting in the floor of the garage.
and the frame, motor, tranny and what not are in the driveway
Old Jun 24, 2007 | 07:31 PM
71dusterdan's Avatar
71dusterdan
okay will this work for my 89? is it easier to replace the floors, rockers and corners, or go ahead and swap cabs? i am picking up a nice bodied 150 6/5gear. thinking i will sell it for 1500, or strip it for the needed parts for my 250. Dan
Old Jun 24, 2007 | 07:57 PM
havi's Avatar
havi
I'll have the Roast Duck
Dan, that 89 cab is heavier. I had one that I lifted with a cherrypicker, but I learned two(maybe more) things. 1: a piece of longer tube will be needed. Mine didn't clear the frame by tightening a ratchet (cgu) strap across the top through the door openings, and picking it off with the hook tightened to the hoist tube. It also swung which left a crease in the top back of the cab, it also seperated the seams at the drip rails by the weight of the cab hanging. 2: The next step was to run big eye bolts thru the cab mounts and criss-cross the chains and bolt them together in the center. This doesn't work well either, unless a couple friends can help balance it. The dash/firewall is alot heavier than the rest. my cab tilted forward on me and went nose diving into the frame. pushing up from inside the cab might stretch the roof's metal, so be careful there, too.
I learned that despite removing the seat and doors, the dash would need to come out, too. With the extended tube, you lose lift capacity, but being careful, it should work. Maybe a spreader-bar set up might work, too. Just watch those drip rails.
Old Jun 25, 2007 | 07:18 PM
71dusterdan
thanks Havi, i was actually thinking that maybe a couple 2x4s under the cab, and a few strong buddies. i will remove the bed, then the cab, so we dont have to lift to far, just up and straight back, and then reverse. i remember those beds being heavy from my bodyshop lacky days, it took between 4-6 of us. yea this is gonna suck but not nearly as bad as trying to repair it. with enough a/kissin i might be able to take it to work and use a crane with the 2x's under it. if i got them both completely ready and just went in to swap them i wouldnt think it would take very long. thanks again. Dan
Old Jul 15, 2007 | 07:08 PM
ssj7kids's Avatar
ssj7kids
Newbee Cab removal 53 F100
Originally Posted by 1Digger
If you have the doors off, you can use the cherry picker from the inside, no extensions required. I have a pic in my gallery of this.
For the steering wheel, I wouldn't bother taking the wheel off if you are taking the column and steering box out too. Remove the acess panels at the column, disconnect the steering box from the pitman arm and frame, and pull the whole assembly out through the cab. Those bolts will probably be easier than getting the wheel off.
My $.02
Ok... I'm confused... but I figure I'm a bigger dope if I DON"T ask....
I have a shop manual that doesn't show a "pitman arm"... but I'm thinking that it's the same thing as the "steering arm".
MY QUESTION...
HOW TO REMOVE THAT NUT??? It is on REALLY tight and has a split nut top???? Sorry to be such a NEWBEE
Old Jul 17, 2007 | 12:02 AM
49fordpickumup's Avatar
49fordpickumup
Disassembly
I just went through the steering wheel removal on a newer thread. Much helpful advice on the subject. On my 1950F-1, I had two frame bolts(one had a cotter key) plus two bolts in the arm on each side of the cab. This is what I found during bolt removal. Rusty threads lodge under the nuts and lockup removal. I used a small wire brush then my tap and die set to clean the threads plus WD-40. The fender bolts were easier to tighten to the point that they twisted off. Mine were rusted to the bed.I used a pair of vice grips on the roundhead bolts if they turned during removal. Back fenders off. Bed off. Cab and front end ready to remove as soon as I can snag some helpers.Have a great day, chuck
Steves55
Nov 16, 2015 10:39 PM
Steves55
Jan 20, 2015 08:03 PM
TexasA&M
Dec 13, 2012 09:26 PM
steve81
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Nov 21, 2006 10:26 AM
Steve Barker
13
Jun 3, 2005 12:12 AM
