C6 shifting issues
Old Jun 17, 2007 | 05:23 PM
ygoldsberry's Avatar
ygoldsberry
C6 shifting issues
Just bought a '73 F100 today, and it had the orginial 360 and tranny swapped out for a '77 400 with a C6 at some point in it's life.
The problem I am having is that after shifting into drive or reverse, after a few mins, it drops{?} out of gear and will not move. The only way to get it to shift again is to shut off the truck for about 5 mins, and then it will shift into gear, but only for a few mins again.
Any ideas as to the cause??
Old Jun 17, 2007 | 06:58 PM
javi2001's Avatar
javi2001
Oil level
Oil filter
Wear at Oil pump
Internal leaks
Perform also a pressure test.
Old Jun 18, 2007 | 07:52 PM
ygoldsberry
ok i just said i did a pressuare test but i was thinking wrong it was a vaccum test
Old Jun 19, 2007 | 08:27 AM
stuart1's Avatar
stuart1
I don't see any mention of any tests being done but this sounds like a low fluid level or clogged filter.
A clogged breather will cause an incorrect fluid reading.
If the breather is clean and the level is correct remove the pan and look for anything clogging the pickup screen.
Old Jun 19, 2007 | 03:31 PM
ygoldsberry
ok well where exactly is the breather located im not that good with transmissons
Old Jun 19, 2007 | 05:31 PM
stuart1's Avatar
stuart1
The breather is on the right side of the transmission above the cooler fitting.
Old Jun 23, 2007 | 07:31 AM
ridgerider3's Avatar
ridgerider3
We adjusted the bands, works good, ridgerider3 is my dad
andercontracting
Mar 12, 2013 01:23 AM
chamblizi
13
Jul 20, 2012 08:25 AM
vanwashe
Feb 18, 2012 01:22 PM
scottyl
Jan 22, 2011 08:32 PM
razorback24
Nov 28, 2008 11:43 PM
