how much hp???????
Old Jun 16, 2007 | 10:39 PM
earlybroncoboy's Avatar
earlybroncoboy
how much hp???????
I have an Edelbrock performer series cam, Edelbrock performer series intake,and an Edelbrock 500cfm carb In my 302, I wonder what kind of hp I'm making . It is freshly rebuilt. I'm wondering cause I might put a different motor in it. I'm looking for more hp. about 300-330.
Old Jun 16, 2007 | 11:59 PM
darrin1999's Avatar
darrin1999
youre probably making around 240-250 horse, maybe a little more if you have headers and higher compression. if you want an honest 300 horse without revving the crap out of it you need more displacement. just swap in a hydraulic roller 351w and maybe an upgraded cam, or if you have a few more bucks to blow, a 408 stroker kit would be good, and you still wouldnt have to change the tranny.
Old Jun 17, 2007 | 11:08 AM
Conanski's Avatar
Conanski
The stock heads are the limiting factor, most dyno sheets I have seen put that type combo at around 275HP. Porting the heads will put it just over 300hp, strappng on a set of AFR 165s will make 400hp.
Old Jun 17, 2007 | 12:48 PM
HemiEater's Avatar
HemiEater
Analysis Report for Street/Strip Engine with Desired HP Peak at 5000 RPM
Peak Tq =270. @ 3500 RPM .9 Ft Lbs per CuIn
Peak HP =226. @ 5000 RPM .75 HP per CuIn
I used e7 heads 8.0 to 1 and 600VS Holley
Just a note it will take a lot more than 165 heads to get that motor to 400HP
Old Jun 17, 2007 | 07:25 PM
daveengelson's Avatar
daveengelson
Not sure if it has anything to do with topic, but came across this article I found informative.
Sorry, came across article in FordMuscle Car forum, however, after posting thread found at some point FORDMUSCLE will prompt to subscribe if interested in getting additional information. Removed the link.
dave
Old Jun 17, 2007 | 08:00 PM
HemiEater's Avatar
HemiEater
He is talking about the performer package not the rpm package....
Old Jun 17, 2007 | 10:48 PM
Conanski's Avatar
Conanski
Stock HO longblock makes 275 crank HP with a carb on it, if this performer cam is the one I think it is, #2122, then I don't see how it could make less.
Old Jun 17, 2007 | 11:53 PM
78f-150Supercab's Avatar
78f-150Supercab
The goal of the Performer packages is to make .7 - .9 of hp/ci. According to that, you could be making anywhere from 210-280 hp.
Here's an HP curve from Edelbrock... of course, they fail to mention what year 302 they started with:
http://www.edelbrock.com/automotive/2121graph.html<hints id="hah_hints"></hints>
Old Jun 18, 2007 | 04:20 AM
HemiEater's Avatar
HemiEater
the performer cam is 204 214 @.050 .447 .471 lift
thats a 4500 to 5000 max cam....
Old Jun 18, 2007 | 04:22 AM
HemiEater's Avatar
HemiEater
thats the torque curve not the hp curve............
Old Jun 18, 2007 | 11:44 AM
78f-150Supercab
Oh... whoops... duh lol.
Oh well, still good for him to know.
Old Jun 18, 2007 | 12:52 PM
shuttlevalve's Avatar
shuttlevalve
8 to 1 compression??? stock is running about 9 to 1. I'm sure you can run near 10 to 1 on premium running cast E7TE heads. I'm going for about 9.2 to 1 so i can get away on 87 octane with my 347 that i'm building up. dropping it 8 to 1 on the computer loses about 20 25 hp and the same in torque.
Old Jun 18, 2007 | 12:54 PM
HemiEater's Avatar
HemiEater
Not sure what he is running for compression......I took a guess
Old Jun 21, 2007 | 03:15 PM
bronco69's Avatar
bronco69
put a cleveland 408 stroker in ur bronco ,mines putin out about 750HP
Old Jun 21, 2007 | 03:47 PM
HemiEater's Avatar
HemiEater
you got a PM
