Finding GVWR?
Old Jun 16, 2007 | 04:29 PM
ford390gashog's Avatar
ford390gashog
Finding GVWR?
I just got a 76 F-250 supercab for 20.00 with a clean title that runs and drives just needs a P/S pump and some minor things. But it only has a vin on the frame and the one on the pinkslip no rating plates. In order for me to register it for farm use i need to know the GVWR. Is there any way to get the GVWR from the vin#?. The vin is F25MKB79881
Old Jun 16, 2007 | 04:50 PM
Mil1ion's Avatar
Mil1ion
what rear axle does it have ?
http://storm.tocmp.com/ford/pickup/1976/1011.jpg
Old Jun 16, 2007 | 05:29 PM
ford390gashog
The rear axle code is C7 3.54 limited slip 5300 lb
Old Jun 16, 2007 | 05:44 PM
Mil1ion's Avatar
Mil1ion
8 ft box ....Then it's either 7500 or 8100 lbs.
Old Jun 16, 2007 | 05:52 PM
ford390gashog
Yep 8' box. I guess i will go ahead and register it as 8100.
Thanks Dennis!
Old Jun 16, 2007 | 06:08 PM
Jermafenser's Avatar
Jermafenser
That picture show the '76 Supercab, 8ft box having either: 6600, 7100, 7500, 8100.
Does the front brake have the dual piston calipers? That's a sure sign that the F250 has a higher GVW package.
Old Jun 16, 2007 | 06:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What is the actual GVWR?
Want to know for sure?
The R/L front axles have ID numbers on them.
If the S/C has the right axle ID number of D5TA-8-CA or DA it has a GVWR of 8100 lbs.
Left axle ID will be D5TA-9-CA or DA for 8100 lb GVWR.
Post whatever ID code you find. It will lead directly to the correct GVWR that a Super Cab of this vintage has.
Old Jun 16, 2007 | 06:39 PM
Mil1ion's Avatar
Mil1ion
Depends on rear axle and tires Jerm.
He said he had the 5300 lbs rear..thus the 2 choices he has.
6100,7100 don't apply in his case.
Old Jun 16, 2007 | 06:46 PM
NumberDummy
1975/79 Super Cab: 6300; 6600; 6900; 7500; 8100.
Text = Section 30; Page 1.
Old Jun 17, 2007 | 02:32 AM
ford390gashog
Yes, the front has dual piston calipers.
the pass side has D6TA-8-EA (diamond symbol) 4
the drivers side D6TA-8-EA (diamond symbol) 2
Old Jun 17, 2007 | 03:10 AM
NumberDummy
D6TA-8-EA = 7500 lbs.
