Water temp sensor
Old Jun 16, 2007 | 04:25 PM
jlutes's Avatar
jlutes
Water temp sensor
I want to find my water temp sensor on my 1995 F150 4.9L but the liature on its location isn't clear. Can I get to the sensor easly or I am I going to need to remove parts to get in there?
Old Jun 16, 2007 | 05:23 PM
ridgerider3's Avatar
ridgerider3
Take a look at this web page;
http://www.autozone.com/servlet/UiBr...3d800a1365.jsp
Looks to me like it is located under the #6 intake/exhaust, with only the one plug to remove to twist it out.
Looks like it should cost around $20 to $30 depending on where you by it from.
Old Jun 16, 2007 | 06:11 PM
javi2001's Avatar
javi2001
There are 2 Temperature sensor.
One is located at the T'stat housing and is used by PCM
Another is located at engine block, right under the intake #6 and is used by Temperature gauge at instrument cluster.
Old Jun 17, 2007 | 10:15 AM
jlutes's Avatar
jlutes
Yes there are two senors I need to get at the temperature gauge under the intake of the #6 cylinder...
Any segestions how to get at it with as little work as possible.
Old Jun 17, 2007 | 11:06 AM
javi2001's Avatar
javi2001
In my experience, the best way to reach it is getting under truck, right under Starter you can pass through your right hand and tool. Cold engine of course but you have to remove first the coolant from engine or can get a coolant bath...
There is no need to remove any more parts...
There is an alternative way, using 2 long extensions (12" each), socket and ratchet been positioned at the right fender. After disconnecting the sensor wire, you can reach the sensor.
Old Jul 19, 2007 | 01:48 AM
henryd's Avatar
henryd
i have 2001 ford f250 powerstroke 7.3 my question is. ive only taken my truck to ford dealer maybe twice this last time it took them aprox.30 days to get my truck done. iam the first owner so i know how my truck runs.i picked up my truck today driving home i heard the fan clutch kicked in. in the six years that i drove this truck all of a sudden this happens. so i flip a uturn went back to the dealer. explain what had happen. they said its normal that the clutch is doing its job or that maybe my raidiator is fool of bugs and not getting enoughf air? so i clean the raidiator its free of bugs its still doing it. after checking the truck and radiator i notice the ECT sensor {engine coolant tempeture} had teflon tape look like it was remove.?I know ford dont normally use white teflon tape. unless they remove it.ill never take my truck to the dealer again
Old Jul 20, 2007 | 08:14 AM
javi2001's Avatar
javi2001
Please post in the proper forum...
riverratmike
Modular V10 (6.8l)
Jan 19, 2018 11:05 AM
Branjo
58
Dec 2, 2016 07:40 AM
jereli
Sep 5, 2011 05:10 PM
Smokey0210
Oct 13, 2003 07:31 AM
KJKozak2
Jun 30, 2003 09:15 AM
