Sponsored by: Real Truck
Water temp sensor location??
Old Feb 9, 2011 | 01:31 PM
jereli's Avatar
jereli
I have 2006 250 diesel...i will be installing an after market water temp guage... My question is where is the factory sensor located? So that I can remove it and install a t fitting in its place and instal my after market sensor as well as the factory one again.
Old Feb 9, 2011 | 07:46 PM
Nice Work Truck's Avatar
Nice Work Truck
There is a plug on the drivers side of the block.
Go under the truck near the rear, above the exhaust manifold.
Old Feb 9, 2011 | 08:26 PM
jereli's Avatar
jereli
Will the fluid spill when I remove it?
Old Feb 10, 2011 | 04:29 AM
Nice Work Truck
Yes you will take a bath in it but from what I have heard it is the best place to put it.
The other option is to put it in a coolant filter housing if you have one.
Old Feb 10, 2011 | 07:25 AM
jereli's Avatar
jereli
Thanks kinda figured...so can i just drain the fluid nto a large enough container or something and then just put it back in when iam done ? Right? New to all this.
Old Feb 10, 2011 | 09:42 AM
thedaddycat's Avatar
thedaddycat
You will get some coolant loss but not all that much came out when I did mine. You should prep the parts before hand, fitting the sender to the adapter (I used teflon paste pipe sealant) and have the sealant on the adapter threads before you remove the block plug. I lifted this from an earlier post I responded to...
"If you have the 6.0 then there is a block plug on the driver's side near the rear that you can get to from below the truck. You will need an adapter, Autometer part #2268, 16X1.5MM to 1/8NPT that fits the block and accepts the standard 1/8 NPT temp probe.
As far as wiring in a selector switch to allow you to monitor multiple inputs on the same gage, check out how I did it in the linked post. I currently have it set up to read front diff, tranny, rear diff, and coolant. I will add oil temp when I install the ESP luber and Oil Guard at the next oil change.
https://www.ford-trucks.com/forums/68...ut-gauges.html "
Hmmm.... I tried the link from this post and it didn't work, so here's the link to the post I lifted it from, seems to work OK from there.
https://www.ford-trucks.com/forums/7...-location.html
Old Sep 5, 2011 | 05:00 PM
jereli's Avatar
jereli
Does anyone have a link with some pictures or have any photos of this location. I have looked from beneath the truck but stil cannot find where this location is at.
Old Sep 5, 2011 | 05:10 PM
Nice Work Truck
Maybe this will help.
Install Pictures
CrispyWafer
Dec 29, 2016 10:38 PM
Glenn Bro
Oct 13, 2016 04:49 PM
cutlass
Jun 13, 2012 11:18 PM
FairmontKevin
Modular V10 (6.8l)
Aug 27, 2011 10:26 PM
KJKozak2
Jun 30, 2003 09:15 AM
