Help Me Prime My Pump
Old Jun 15, 2007 | 11:10 PM
indebt's Avatar
indebt
I cant get that dang pump to pull fuel, I have about ten gallons in there now and keyed it about 10x's til it shut off, but no go. WHat do I do to get this puppy started, thanks
P.S. this is after my hutch mod
Old Jun 15, 2007 | 11:19 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Pour diesel in from the other end. Are you sure the pump is running?
Old Jun 15, 2007 | 11:55 PM
indebt's Avatar
indebt
yes sir I can hear her screaming for fuel, what does diesel from the bowl do ? help it pull or what?
Old Jun 16, 2007 | 12:07 AM
Tenn01PSD350
Well, you want to prime the pump and there are no check valves from the fuel bowl to the pump that I know of. So ease it in the bowl and the air will work it's way out. Do it slowly as gravity is your friend. You will not be able to get all the air out but you should at least be able to clear it to the pump, and then some. Maybe all if it pushes it out through the tank. That is the objective, priming the pump if it is running.
Old Jun 16, 2007 | 12:21 AM
indebt's Avatar
indebt
cool i will try it in the am, thanks alot!!!!!
Old Jun 16, 2007 | 08:09 AM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
maybe its starving for fuel, your intank mod might have to be checked, looks like your suction line might be bottom out and unce you turn the pump on it will stick to the bottom of the tank, to prime your pump it takes one turn of the key and you should be set, when i did my after first key turn my Dahl 150 and fuel lines were primed and had my set PSI on my gauge(but i have regulated return ), so you not getting fuel, if after 10 key turns you dont have fuel in the bowl, . let us know whats up
clux's Avatar
clux
I've had my pump and fuel lines out several times, but never had trouble getting the pump to move fuel without priming. Did you check the lines over the tank to make sure something didn't get kinked when you reinstalled the tank? I know I had to be careful putting the tank back up to avoid kinking/pinching the lines.
Old Jun 16, 2007 | 08:11 AM
PETE'S_6.0PSD
thats another good idea Clux i forgot about that ,
Old Jun 16, 2007 | 10:10 AM
F250_'s Avatar
F250_
I am watching this one with great interest because I'm doing my in-tanks next weekend.
One thing this discussion has brought to my little mind is that whenever i put the pickup line back in, in order to prevent it from "bottoming out, I'm going to cut the end in the shape of a point with opposite sides being bevelled at 45°. That way, if it does bottom out, it will only stick on a short piece of the line's end and the line will remain open. Do you guys think this would work?
Old Jun 16, 2007 | 10:15 AM
rbaker6336's Avatar
rbaker6336
blowing air into tank is easiest way to prime the pump although as stated should self prime
Old Jun 16, 2007 | 10:41 AM
empiretc's Avatar
empiretc
Beat me to it. Its what I had to do after I did the hutch.
I learned with this truck though, if you want it to prime on its own
YOU MUST FILL THE TANK!!!
try that, then use the air hose!
Old Jun 16, 2007 | 12:04 PM
clintbonnie's Avatar
clintbonnie
You can also disconnect the fuel line at the intake side of the pump and take a length of fuel hose and reattach it to the pump and stick the other end in a container of diesel fuel.. That would show whether or not the problem is in the tank or not..
Old Jun 16, 2007 | 12:22 PM
indebt's Avatar
indebt
well after ten key turns nothing, the fuel bowl is empty. So I tried filling the bowl and see if it will flow back but its at the same level as before. So do I just stick a hose and blow air thruogh the smaller tube of the filler. I really dont want to pull the tank again it was a ***** by myself!
Old Jun 16, 2007 | 12:23 PM
indebt's Avatar
indebt
what if I didnt tighten the fitting enough would that jack it up?
Old Jun 16, 2007 | 12:34 PM
Action4478's Avatar
Action4478
I read before that someone pressurized the tank a little with a shop vac,,,( carefully).....
