Known cooling problems?
Old Jun 17, 2007 | 08:58 PM
Holmesuser01's Avatar
Holmesuser01
If you havent done it yet, replace the thermostat.
Old Jun 17, 2007 | 09:08 PM
CaptGuz's Avatar
CaptGuz
I need to. Have not done so yet. Truck seems ok right now, dont really want to drain the 2 gal's of antifreeze i just put in it because i dont have an easy way to get it back into the system after i dump it. wasn't going to drive till i replaced the t-stat but a friend told me he's give me a truck box today - yea - he lied again. guess i wont be considering him a friend anymore
Old Jun 18, 2007 | 12:49 PM
TrucksNamed"PHIL"'s Avatar
TrucksNamed"PHIL"
Filled back up with antifreeze/coolant ready mix (2 gal)
By "ready mix", do you mean the pre-mixed 50% stuff? Sounds like you might have a 25:75 coolant:water mix now. If you wanted a 50:50 mix you should have added 2 gal 100% coolant instead of the ready mix. I think your coolant capacity is 17qts, for simplicity lets call it 16qts. 16qts=4gal.
After you flushed the engine w/ clear water and drained w/o removing engine drain plugs, you had 2gal of clear water left in the engine. Add 2gal of 100% and you'd get a 50:50.
Old Jun 18, 2007 | 02:54 PM
CaptGuz's Avatar
CaptGuz
oh well... its working well.
fbh31118
67
Jun 19, 2014 01:24 PM
abyars111
18
Oct 26, 2013 11:52 AM
ernesteugene
Sep 24, 2007 07:14 AM
gary502
19
May 17, 2007 06:35 PM
C G
43
Mar 12, 2006 10:04 PM
