Windshield Wiper Linkage Question
Old Jun 15, 2007 | 10:47 AM
TexasGuy001's Avatar
TexasGuy001
Question Windshield Wiper Linkage Question
The wipers on my truck seem sloppy and don't always stop all the way down. They can be slightly moved independently of each other. Sometimes its the left sometimes its the right that stay up a couple inches. Also, the driver side one is now hitting the stainless or aluminium trim around the windshield.
Has anyone ever replaced the nylon bushings that connect the wiper linkage under the cowel? I have a very good idea that they are worn out or broken on my truck. I need to know how many of them there are and which ones to get before I go to the store to get them. Also, is there a special tool required? If anyone knows anything that might make this easier, please share.
Old Jun 15, 2007 | 05:01 PM
netscaner's Avatar
netscaner
From what I know, they aren't available ANYWHERE.
Ford wants to sell you the whole assembly at over $ 100.00. Way over !
On my 1993 Mercury Villager, I snapped them off the ***** and greased the *****. I then cleaned out the nylon inserts with brake cleaner. I mixed up some JB Kwik and QUICKLY coated the inside of the insert with it. I then forced it onto the ball. When the unused Kwik on the mixing palet seemed firm, but still somewhat pliable, I turned the insert on the ball to make sure it wasn't seized as the epoxy further set. In about an hour your good to go for at least a few years.
Old Jun 15, 2007 | 05:47 PM
lostin90s's Avatar
lostin90s
LMC has em ,at least the wipper pivot arms (L 24.95- R 19.95 ) ,and wiper pivoy clips (1.95) Look at thier on line catolog at www.LMCTruck.com
But I have replace parts of it with used ones I have . On a occasion or 2. Try to find a tight use set. I have 2 parts truck that are good so I know they are out there Plus the one I'm driving. . Good luck
Old Jun 15, 2007 | 08:41 PM
TexasGuy001
I have seen a few different styles of the white nylon bushings in the HELP section at the local parts store. I was just wondering if they are the larger or smaller ones. The pivots with the little splines where the wiper are attached are tight and don't have any slop or play in them.
Old Jun 15, 2007 | 08:59 PM
netscaner's Avatar
netscaner
Wow.
May I ask what kind of local parts store has them ??
Old Jun 16, 2007 | 04:37 AM
TexasGuy001
I saw a couple different packages of different sizes of them at autozone. I'm fairly sure that almost anyplace that has the HELP products in the red packages has them. The company that makes the help line is Dorman. You may have to look closely through the items they were hard to find.
I wonder how hard they are to replace though. Does anyone think I will need some new clips also?
Old Jun 16, 2007 | 10:08 AM
lostin90s's Avatar
lostin90s
If the parts store has a selection of help they have a catalog you can look at to see if have. good luck
Old Jun 17, 2007 | 01:21 PM
TexasGuy001
Thumbs down
Well, I disassembled everything and replaced the nylon bushing. They were trashed. I have an issue with the pivot that the wiper arm mounts to on both sides. I'm not sure if that is what it is called, but it has splines on it. They are all sloppy and lose. I guess they are worn out. If you ask me thats just crap. They should still be in good working order. Is this something that people have has alot of problems with going out? I can't find any of them locally. One would think that the auto parts store would have them. This is weak! I don't understand why the housing isn't metal. Its plastic and the metal internals wore it out and it couldn't take it. Thats just my guess.
Old Jun 27, 2007 | 07:41 AM
TexasGuy001
I replaced the whole assembly since it comes with the linkage and nylon bushings etc. The problem is gone now. I got them for about $20 each from LMC.
CountryBumkin
Feb 2, 2016 05:32 PM
Dave145
Apr 17, 2014 03:18 PM
ZukBox II
Oct 11, 2010 03:01 AM
karnett
May 31, 2006 02:17 AM
Hamberger
Jan 30, 2006 09:31 AM
