1988 Ranger A/C
Old Jun 14, 2007 | 11:33 PM
Shovel71head's Avatar
Shovel71head
1988 Ranger A/C
The A/C blows cold very briefly then blows regular temp air. I have had the A/C system recharged. I have been told it may be a relay, that is a laugh there are at least 6 different relays linked to the A/C system. Any ideas on which one to start with.
Old Jun 15, 2007 | 08:43 AM
lsrx101's Avatar
lsrx101
Actually, you probably have a clutch gap that's too wide. As things heat up, the expansion takes it slightly wider, beyond the limit that the coil can pull it in.
You want less than .020. You take the clutch center bolt out and slide the clutch plate off. There are shims on the end of the shaft.
burgerking579
Aerostar
18
Jul 20, 2021 12:05 PM
mshargrave23
Sep 15, 2013 12:02 PM
5504x4drwcrew
Oct 16, 2011 09:42 PM
chaneyb
Jun 21, 2005 03:42 PM
2fords9kids
Jun 19, 2005 11:08 PM
