6 volt coil
Old Jun 14, 2007 | 10:37 PM
48ATOY's Avatar
48ATOY
6 volt coil
on a stock 6 volt ing.
is there a voltage reducing resistor on the system
I have to replace my coil spark jumping cracked top
on some 12v you need a resistor?
Joe
Old Jun 15, 2007 | 06:25 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Joe
Not sure I fully understand your question. A 6V electrical system requires no resistor. A 12V electrical system should have an external ballast resistor to limit voltage across the points to 6V.
Old Jun 15, 2007 | 09:01 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Some 12v coils have the ballast built into them, others don't. You need one somewhere.
Old Jun 15, 2007 | 10:05 AM
dffay's Avatar
dffay
So why is it that there needs to be a difference between 6V and 12V coils? If a coil does the same thing to voltage, why does the input matter? Shouldn't there just be one coil and 6 volts input does what it does and 12 volts does what it needs to?
Questions of life I often ponder
Old Jun 15, 2007 | 02:04 PM
GreatNorthWoods
A coil is basically a step up transformer. If it's designed to accept 6V and you give it twice that then it's not going to last very long...just like any other 6V appliance that is fed 12V. On older vehicles with a point type ignition system, only 6V goes through the points regardless of whether the vehicle has a 6 or 12 volt electrical system, but on a 12V system you need the ballast resistor to reduce the voltage to the points to 6V to extend point life. You can run 12V through the points for awhile but they don't last long if you do.
Old Jun 15, 2007 | 04:11 PM
dffay's Avatar
dffay
Thanks, but its not a regular appliance that is supposed to do from a certain voltage input and only that work. A transformer is a linear arrangement that steps up, so if a 12volt coil were only fed 6 volts, its should act like a 6 volt coil--step up transformer--shouldn't it?
Old Jun 15, 2007 | 06:56 PM
sparky's Avatar
sparky
Not a prob giving 6 volts to a 12 volt coil, 70's duraspark system actually run between 7-9 normally. The problem with 12 to a 6 coil is it will heat up and the insulation will break down and then the smoke leaks out and it stops working. I have learned that once smoke leaks out of something electrical it usually ceases to function...... and I have never managed to catch all the smoke and get it back in yet
Old Jun 16, 2007 | 05:38 AM
GreatNorthWoods
My only experience with this was many years ago when I converted a 6V system to a 12V on a 34 Plymouth. I forgot about changing the coil and it worked fine for about a week before it burned up...
Old Jun 16, 2007 | 06:47 AM
stewards68's Avatar
stewards68
Extensive idiot training has taught me that you CANNOT afford to let the magic smoke escape from any electrical components... That's BAD...
I'll admit I've forgotten more than I know about all this, but I was of the understanding that the voltage drop let the points last longer as well.
Old Jun 16, 2007 | 09:42 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Essentially they did the same thing with coils that they did with the gauges, when they went from 6v to 12v. Instead of a CVR like on the gauges, they used a ballast resistor, which is not a linear resistor. They are nichrome-wound filaments and the resistance changes with temperature. At idle the ballast gets hotter and has higher resistance, which is OK because the engine needs less spark and it keeps the coil cool and maximizes point life. That is also why they bypass the ballast on Ford 12v starter solenoids, it would otherwise be getting a weak spark. At higher speeds the ballast runs cooler and its resistance is somewhat less, and gives a hotter spark which the engine needs because it has higher compression pressures (higher cyinder fill).
The Ford cars with 6v systems actually had ballast resistors in the late 40's. I've never figured out why.
streetrod00
Jun 16, 2014 07:48 PM
Steves55
Apr 8, 2014 08:14 PM
the Canadian
Apr 18, 2012 11:00 PM
scott0531
Aug 6, 2008 01:17 AM
1ford1
Sep 7, 2007 07:47 PM
