CCK & #8LL
Old Jun 14, 2007 | 08:45 PM
MR5x5's Avatar
MR5x5
CCK & #8LL
What's the conventional wisdom on whether or not the long lead #8 injector should be relplaced as part of the CCK mod?
Old Jun 14, 2007 | 09:22 PM
Pocket's Avatar
Pocket
It is "recommended" but not necessary. The LL is no longer needed when you eliminate the deadhead on the driver's side fuel rail. Swapping it out with an AD injector gets rid of that last bit of cackle. On my engine when I swapped out the LL, I improved rotational velocity on that cylinder and eliminated the bit of knock on #8.
Old Jun 15, 2007 | 08:29 AM
F250_'s Avatar
F250_
It is a costly "recommendation", though (injector, gaskets, etc.). I'm going to wait until I have to do injector work to eliminate the LL.
