Decode tranny tag
Old Jun 13, 2007 | 08:37 PM
OldFords's Avatar
OldFords
Decode tranny tag
Can someone decode the data tag I found today on the transmission in my wife's 1987 Ranger?
The numbers are:
85GT AEA 1
04 E 18
Thanks,
OldFords
bad attitudes
Old Jun 14, 2007 | 06:25 AM
slc10844's Avatar
slc10844
Is it the orginal transmission? The 04 E 18 are suppose to represent the year, month, and day built.
Old Jun 14, 2007 | 07:44 PM
OldFords's Avatar
OldFords
I believe the engine that was in the truck when we got it was a replacement for the original motor. The reason I think this is because whoever put it in removed a lot of the computer sensors and put a Motorcraft two-barrel V8 carb on it. Also, it was a 2.8, not a 2.9.
I had to remove the engine because it started knocking (loose rod). When I pulled the pan, I found the crankshaft to be trash. So I put an earlier Bronco 2.8 V6 in it. I did not replace the tranny, but I think it was changed when the original 2.9 V6 was rplaced. I don't think it is the original A4LD, but I'm not sure. That's why I would like to ID the tranny, if I can.
The tag looks to me to be very similar to the data tags found on Ford differentials.
OldFords
bad attitudes
OldFords
Jul 25, 2005 12:07 PM
884x4broncoII
Bronco II
Jul 3, 2005 12:49 PM
oldfords4ever
Aug 7, 2004 06:22 AM
OldFords
Mar 11, 2002 09:27 PM
oldford64
Oct 7, 2001 09:49 AM
