second question on the vss
Old Jun 13, 2007 | 04:06 PM
bobpat204's Avatar
bobpat204
i started a thread about my problems with my truck those that responded all agree its the vss, so i pulled out what i thought was the vss from the rear axle and looked it over cleaned it up put it back in,still have troubles on the way to work today, so i stopped off at napa,and autzone on the way in to see about getting a new sensor they both brought out this unit that looks like it would go in the tranny>?my question this thread is, is the vss the sensor in the pumpkin or is it in the tranny??? if it is the sensor in the rear end anybody have a good part # or know where i can get one??? thanks
Old Jun 13, 2007 | 07:12 PM
David85's Avatar
David85
1992 and older had a vss on the rear of the tranny at the speedo cable, 1992 and later eliminated the speedo cable and moved the vss to the rear differential.
Old Jun 13, 2007 | 07:26 PM
bobpat204's Avatar
bobpat204
thanks for the reply i thought the one on the rear end was it but cant seem to get a good part number or find a place that has one the best i have found is online and it is called an "abs"speed sensor but the pic sure looks like mine.
Old Jun 13, 2007 | 07:35 PM
David85's Avatar
David85
I believe the vss doubles as the abs signal for the rear brakes. If it looks the same than it probably is.
Old Jun 14, 2007 | 08:44 PM
bobpat204's Avatar
bobpat204
thanks for the support,problem solved after replaceing the"abs differental sensor", $13.99 from autozone new name for the vss i guess.thanks all
Old Jun 14, 2007 | 08:54 PM
David85's Avatar
David85
Nice when a fix is that simple, glad to hear it.
Old Jun 18, 2007 | 09:40 AM
Kemicalburns's Avatar
Kemicalburns
I to have no speedometer right now. went thru the same issue at the parts store. so when you replaced that abs sensor your speedo started to work again? I for the life of me can not find where the vss that i bought for a 94 bronco even goes.
