Sweet junk yard deal
Old Jun 16, 2007 | 07:56 PM
72f2504x4390's Avatar
72f2504x4390
Went to my local self serve to get some gears today, left without the gears but got....
Injection pump, injector lines, injectors, glow plugs, fuel filter/water seperator header from a 91 7.3.
Heres the kicker. Went to pay, the guy says "whats that?" Injector pump, he says "I have only sold 2 of those in 5 years, we got no pricing for that. How about $12?" Ok, then he didn't charge me for the rest of it.
So I walked out with all of the above for $12 plus the governors cut.
Cover had the provision for a tach drive, but the drive is gone. Someday I will find one of those.
So question. Will these interchange with my 84 6.9? and has anyone rebuilt an IP before. I found somewhere that had rebuild kits, couldn't be that hard?
Old Jun 17, 2007 | 12:08 AM
PLC7.3's Avatar
PLC7.3
I'd make friends with that parts guy.........find out when he works and be there a lot. Just the core for the IP is more than he gets paid for a weeks work obviously.
Old Jun 17, 2007 | 07:37 AM
F250FarmBoy's Avatar
F250FarmBoy
Wow what a steal, really, you basically stole those things......lucky stiff.
The glowplugs aren't swollen or anything are they? Are they good beru Germany ones?
I wish i was as lucky as you.
Old Jun 17, 2007 | 08:04 AM
72f2504x4390
Glow plugs are not swollen and are champion. Tested them with an ohm meter and 6 test good, then hit them with power and only 3 got hot quick, the other 3 got hot but took a long time. Going to keep the 3 and toss the rest. Figure they will be backups.
Going back this morning to get the glow controller and starter, maybe tranny if its still there. Was a 5 speed, but there was a guy working on getting it out when I left maybe he didn't have all the tools he needs
Old Jun 17, 2007 | 08:31 AM
Franken-Truck's Avatar
Franken-Truck
Hehe. . .I love when that happens, I almost feel guilty. Almost. . .
Uh, wrong forum! Gonna dip back out
Old Jun 17, 2007 | 09:50 AM
PLC7.3's Avatar
PLC7.3
I would not save the Champion GPs turf them all........ only use Beru/Motorcraft available at Autozone for under $10.
Read.... http://www.members.shaw.ca/k2pilot/
Old Jun 17, 2007 | 11:11 AM
72f2504x4390
[QUOTE=PLC7.3]I would not save the Champion GPs turf them all........ only use Beru/Motorcraft available at Autozone for under $10.
Read.... http://www.members.shaw.ca/k2pilot/[/QUOTE]
Ok, first I thought so what if they don't last. But now, no way I will use them. Will keep them around for something though. Probably use them for something someday(not in an engine). I am a packrat.
Old Jun 17, 2007 | 05:26 PM
AndysFords's Avatar
AndysFords
I used my old ones to plug a fuel line, and several other things!
Old Jun 17, 2007 | 06:30 PM
Franken-Truck
Have a sling shot? Small stuff like that is super fun to rocket off into the beyond, or for taking out squirrels
Old Jun 17, 2007 | 09:04 PM
CheaperJeeper's Avatar
CheaperJeeper
[QUOTE=72f2504x4390]
I've seen where they make a good inline heater for WVO. Use a 3/4" brass T-fitting with bushings in all 3 ports of the T. Screw the glow plug into one of the bushings in the straight "top" part of the T and the input and output lines into the other 2 ports....
Old Jun 18, 2007 | 11:10 AM
460429_freak's Avatar
460429_freak
[QUOTE=CheaperJeeper]
wouldn't they get to hot and burn out? you couldn't leave them on for to long...
