351w crank comparison
Old Jun 13, 2007 | 03:04 PM
SPRPRBGT's Avatar
SPRPRBGT
i have a 1974 marine 351w standard rotation. and i need a crank for a 1988 351w efi block. will the crank from the 74 work in the 88????? sorta need a quick answer
Old Jun 13, 2007 | 06:40 PM
HemiEater's Avatar
HemiEater
try it .......don't see why not as long as the rear seal is the same......
Old Jun 14, 2007 | 01:26 AM
Beanscoot's Avatar
Beanscoot
I seem to recall that the reverse rotation cranks have the angled "scratches" on the rear main seal surface sloped the opposite way. So instead of tending to pull oil back into the engine, the tendency will be to pump it out.
Old Jun 14, 2007 | 03:03 AM
HemiEater's Avatar
HemiEater
Old Jun 15, 2007 | 01:20 AM
Beanscoot's Avatar
Beanscoot
Ah yes... I don't know why I thought reverse rotation. I suppose I was thinking of another post.
Old Jun 17, 2007 | 10:30 PM
1963f100's Avatar
1963f100
Does the 88 engine have a one peice rear main seal? If so, there is an oil slinger on the rear journal will have to be machined off of the 74 crank to be used in the 88 block.
ranger1985
Jun 19, 2010 07:57 PM
NoAZ'68
Jan 2, 2005 09:48 AM
Texas54
Aug 10, 2004 04:20 AM
pcmenten
Jun 22, 2003 01:33 PM
1ole4d
Mar 17, 2003 06:24 PM
