My truspeed box goes inline with gray wire w/black stripe that goes into the bottom of the abs module. The module is inside the wheel well at the front on the drivers side
Is it the box that sits down low behind the headlight ?
If so, How the heck do you get at the wiring?
Pull the wheel well liner out on the front enough so that you can get at the wiring harness. Peel the plastic off of the wires and it should be gray w/black wire.
