Bronco II Ford Bronco II
Transmission Options
Old Jun 12, 2007 | 03:02 PM
whitetrash's Avatar
whitetrash
Hi every body; most of my time spent here is in the 67- 72 forum, but I just bought an ’87 B2 off of eBay. I haven’t seen it yet so maybe my question will change when I do.<O</O
I was told that the transmission is gone (not with the Bronco). It was a Mitsubishi, the owner bought a used transmission (that will be with the Bronco), but it is a Mazda Transmission. They are under the impression that the Mazda Transmission will not work with the B2, and have told me that I need to buy a Mitsubishi 5 speed. In searching the forums it appears to me that the Mazda Transmission may work fine.<O</O
So should I be looking for a Mitsubishi 5 Speed, or will the Mazda 5 Speed work?<O</O
(1987 Bronco II, 4wd, 2.9L Engine)<O</O
Thanks
Chad
Old Jun 12, 2007 | 04:15 PM
Aggie05's Avatar
Aggie05
IM not a tranny guy but welcome to the B2 forums! IM sure you will enjoy the B2 once you get it going. There are some very smart people on here so just hang in there and you can get anything answered.
Old Jun 13, 2007 | 11:25 AM
Canadianice's Avatar
Canadianice
Well from what i understand the Mazda tranny is the favored transmission around here. But to be sure check out if the tranny is the right one, go the www.therangerstation.com and see if you can dig up any info on the transmission that came with your purchase. Perhaps you are lucky and got a better transmission.
Old Jun 14, 2007 | 11:31 PM
kernel-panic's Avatar
kernel-panic
Is it the M5OD or the T-K 5? Either way, I believe there are length differences that will need to be addressed, as I am unsure if your tranny crossmember will have to be relocated or what, not to mention the driveshafts may not work. That is probably why they told you that the transmission "won't work".
http://therangerstation.com/tech_lib...nsmission.html
Old Jun 15, 2007 | 09:45 AM
mrshorty's Avatar
mrshorty
The other major consideration is which engine the Mazda came from. The M5OD has an integral (non-removable) bellhousing. If the particular M5OD included came from anything besides a cologne V6, the bellhousing bolt pattern won't be correct.
Tim Hodgson
45
Oct 5, 2015 10:25 AM
K8's Ford
13
Oct 19, 2010 05:39 PM
white Buffalo
Mar 12, 2008 12:27 PM
johnnydmetal
Exhaust Systems
Jul 30, 2007 03:35 AM
bigdavesohc
May 27, 2006 11:26 AM
