Question??????
Old Jun 12, 2007 | 10:13 AM
bsteele52's Avatar
bsteele52
Question??????
My front fenders are rusted in the seam where the top and bottom pieces bolt together.(1950) The rust is pretty bad in both the top and the bottom. Can these be fixed: patch panels or anything? Or should I just go with fiberglass?
Old Jun 12, 2007 | 10:28 AM
rhopper's Avatar
rhopper
Patch panels are available from several sources, or pm reamer and see if he makes them. That is a common rust area on those trucks, mine were bad too. Making your own panels is not that hard, the curves are pretty straightforward. $10-$20 worth of sheetmetal should get you all you need.
Old Jun 12, 2007 | 12:34 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I was going to do that on my '52, it is not as simple as you'd think. If you have $2k worth of stretchers, shrinkers, forming dies, and can match the compound curves, no problem. They do sell patch panels but they are not very accurate, and are not made the same way. I went with single-piece fiberglas.
Old Jun 12, 2007 | 01:14 PM
AXracer's Avatar
AXracer
You can get a 2 unit shrinker/stretcher for ~ 300.00 or a single machine with 2 sets of jaws for ~ 175. It can pay for itself in one job. I highly recommend purchasing one or a double unit if you are doing much patch panel work.
Old Jun 12, 2007 | 06:35 PM
rhopper's Avatar
rhopper
Actually, I've made the patch panels he's asking about with simple hand tools. Both the bolt in area he's talking about, and the bottom of the front at the running board attachment point were bad on my truck. The basic curve is simple, and the compound in those areas is slight enough that some hammer and bag will get you there. Once you've welded in the patches, you'll need to fine tune with hammer and dolly. When making patches, remember it's easier to stretch than shrink. You'll wind up using alittle filler, but you'd need some if you purchased patches, too. Take your time and think about what you want the metal to do before you hammer it.
Old Jun 12, 2007 | 07:34 PM
bobj49f2's Avatar
bobj49f2
I made my own patch panels for the front fenders on my F-4. On the top part of the fender the metal was mostly ate away. I made a pattern on cardboard, traced it on to a piece of 12 ga metal and cut the metal to shape. I then used a gas wrench to heat the edge and hammered it over an old piece of railroad rail. I made the rest of the patches out of 16 ga steel I had laying around.
I don't have the money to spend on fancy tools, I use whatever I have laying around.
Old Jun 12, 2007 | 08:40 PM
4tl8ford's Avatar
4tl8ford
Ah Yes, The Zen Art of Metal Bending.
Old Jun 12, 2007 | 10:25 PM
rhopper's Avatar
rhopper
Bobj, my fenders rusted in exactly the same spots! It's funny, I was at an antique truck show this past weekend, a few F1 to F6's there. The unrestored trucks all had rust in the same spots, and the same crack in the front of the hood.
Old Jun 13, 2007 | 06:43 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Go with fiberglass and then you won't have to worry about the rust...ever!
Old Jun 13, 2007 | 06:57 AM
bsteele52's Avatar
bsteele52
With the fiberglass have ya'll seen any spider-web when a rock hits the under side?
Old Jun 13, 2007 | 07:24 AM
GreatNorthWoods
Don't run over rocks!
Seriously, I suppose that can happen but if you get some quality made fenders like from Bebops that should not be a problem.
Old Jun 13, 2007 | 07:48 AM
bsteele52's Avatar
bsteele52
Thanks for all the replies guys. I'm a long way from the body work. Just trying to make plans. Still have to get the bed off(all but two bolts out justing waiting on my help to show up) then remove cab and start stripping the frame.
Old Jun 13, 2007 | 08:29 AM
AXracer's Avatar
AXracer
Hopper is right, anything a machine can do can also be done by hand as well, just that some techniques i.e. shrinking, takes a lot of technique and skill or a lot of cutting and welding. A shrinking/stretching machine does make curving a flanged piece or making a deep compound curve nearly a pleasure. I am very skilled at hand shrinking/stretching, but would never give my machines back.
Old Jun 13, 2007 | 08:35 AM
bobj49f2's Avatar
bobj49f2
Every hood on a '48-50 Ford I have seen has been cracked in the front corners. I cure this problem by brazing a 5/16" flat washes inside around the hole. I never have a problem with a crack again and you can't see the washer once the hood's all together.
The fenders have perfect places for all the road gunk to sit and collect moisture, nice design. The designers never thought the trucks would last longer than 10-15 years, they came with 90 day warranties, and I am sure they never thought there would be a bunch of goofs restoring these old crates 50+ later.
