1988 AC compressor coil problems?
Old Jun 12, 2007 | 09:45 AM
barnetto's Avatar
barnetto
I am having AC problems on a 1988 F-150 with 302 and auto trans. The compressor coil will not pull the hub in to engage the compressor. I have ~13 volts at the coil connector. I bypassed the pressure switch, the system is charged, I bypassed the switch to rule that out as a problem. I checked the hub clearance, it is .030.
I purchased a new coil and hub assembly and installed it with a .030 air gap. The compressor will still not engage. I checked the resistance of both the old and new coils. It is at 3.0 to 3.5 ohms. I tried bumping the hub plate while the engine is running and the coil energized with no success.
I have noticed the coil harness appears to have a diode wired in. Could the problem be too little amperage to the coil? Any help will be appreciated.
Thank you,
Larry B
Old Jun 12, 2007 | 10:39 AM
lsrx101's Avatar
lsrx101
spelling correction
Thank you,
Larry B
Your clutch gap is WAY too wide. You want less than .020, with .010-.015 being ideal. Pull the clutch plate and remove some of the shims.
If your old coil measured 3.0 ohms, the original problem was also likely just the clutch gap. You could have adjusted it.
"I tried bumping the hub plate while the engine is running and the coil energized with no success." Did it engage or not, I don't understand this statement.
Tapping the clutch inward is the test for a wide gap. The magnetic field isn't enough to overcome the wide gap, but if you nudge it a bit, it will pull in and drive the compressor.
All of this is assuming a fully charged system and a good cycling switch.
Old Jun 12, 2007 | 08:19 PM
barnetto's Avatar
barnetto
I was checking the ground and harness connections when I noticed the pressure switch wiring was loose inside the plastic connector. The wire had pulled loose from the metal crimp on the connector. When I jumped the switch yesterday, the connection was probably bad. I had voltage, but not enough current to energize the coil. I crimped a new connector for the pressure switch and now the coil pulls the hub in and operates the compressor.
Thank you for your advice.
Larry B
Old Jun 12, 2007 | 10:40 PM
lsrx101's Avatar
lsrx101
Larry B
Good job. I'm glad you found the problem.
Back off that clutch gap, though. It may give you problems and it only takes 5 minutes on your truck.
dbag
Aug 15, 2012 08:36 PM
sparrky81
Aug 17, 2009 10:28 AM
Ultramagdan
Jun 27, 2008 05:51 PM
barnetto
Jun 12, 2007 08:18 PM
Larry
Nov 19, 1999 11:51 PM
