O2 sensor location
Old Jun 11, 2007 | 07:22 PM
norvillebob's Avatar
norvillebob
O2 sensor location
Folks, I may be going to fuel injection on my 390. I have a very easily to get at location to put an O2 sensor. In the "H" pipe about 18" from the header collectors. Else I'll have to pull a header to install a bung or cut my exhaust and install an O2 collector.
I know closer is better but my "H" pipe is bolted together ans I can pull it and have the bung welded in easily.
thoughts?
bob
Old Jun 12, 2007 | 10:18 PM
LxMan1's Avatar
LxMan1
As close to the header as you can get it is recommended.
Old Jun 15, 2007 | 06:22 AM
norvillebob
thanks, But If I go closer I really can only get about 4"s . I have a crossmember there in the way and the tranny. I thought about the header themselves. But the Drivers side is a pain to get out. And the pass side is easy to remove,but I have to remove it when I need to change the starter. I'm afraid I'll smash the sensor while I'm jamming in a new starter. I'm on my third in less than a year.
Will an "H" pipe see enough exhaust. I know it will take longer for the system to go into a closed loop while the O2 sensor heats up. But will it be getting "good" exhaust???? That's what I'm concerned about most. For tunings sake.
bob
Old Jun 15, 2007 | 06:37 PM
LxMan1's Avatar
LxMan1
As long as there are no leaks, it should read ok.
Old Jun 15, 2007 | 07:44 PM
norvillebob
great thanks
bob
2.5itim
22
Oct 31, 2016 01:57 PM
CaptainJack_7
Jan 20, 2016 09:34 AM
Carloespo
Dec 14, 2015 09:12 AM
Big Sky Highboy
22
Mar 1, 2015 05:30 PM
78Brawnco
Feb 22, 2015 02:30 PM
