6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
what does a PTO do for you
Old Jun 11, 2007 | 07:22 PM
bobbyg's Avatar
bobbyg
Can anyone explain if putting a PTO in your truck helps.
Old Jun 11, 2007 | 07:28 PM
66stang351's Avatar
66stang351
PTO Accessories like a snowplow
Old Jun 11, 2007 | 07:32 PM
bobbyg's Avatar
bobbyg
can you help me understand how a PTO works and how it helps using a plow with it. I hope I am not asking stupid questions
Old Jun 11, 2007 | 07:37 PM
UGA33's Avatar
UGA33
If you have ever driven a tractor, then you will understand what a pto is. The pto powers the attachments. Like on a tracor, the pto powers a bush hog, seeder, and many other things you put behind it. It basically does the same thing. It powers attachments.
Old Jun 11, 2007 | 07:47 PM
66stang351's Avatar
66stang351
A little more info...a PTO is basically a shaft sticking out of the side of the transmission that you can attach things like a hydraulic pump to.
Old Jun 11, 2007 | 08:11 PM
bobbyg's Avatar
bobbyg
But are most plows run on pumps and hydraulics mounted on the plow and not by the engine or the transmission. Like a Fisher plow
Old Jun 11, 2007 | 08:41 PM
66stang351's Avatar
66stang351
Originally Posted by bobbyg
But are most plows run own on pumps and hydraulics and not by the engine or the transmission. Like a Fisher plow
Anything running off the transmission is running off the PTO. I don't actually know anything about snowplow option just was using it as an example. You can also use it for a dump bed or other things
Old Jun 11, 2007 | 09:11 PM
PHWLEE's Avatar
PHWLEE
Here in the FDNY, our apparatus all use a PTO (power take-off) to power the main function of the unit. For example, PTO powers the pumps in the engine companies to drive the impellers that create water pressure, and in the ladders, the PTO powers the hydraulics to enable the use of the tower ladders and such. Basically the engine goes into PTO by throwing a few switches and enables the transmission to power the unit that is attached to it. This disengages the drive axles but engages the PTO unit. So you're actually in "drive" but are not moving. Rather, the engine is cranking and the transmission is powering the accessory. Basically, it is using the power that is already there, namely the drivetrain.
Old Jun 11, 2007 | 09:48 PM
kimminau2's Avatar
kimminau2
The PTO generator is a cool accessory. I have the PTO option but other than the generator I don't know what I would ever use it for.
Old Jun 12, 2007 | 01:16 AM
SouthTexasDiesel's Avatar
SouthTexasDiesel
Where can you find accessories for PTO's? I'd like to know if they make PTO powered air compressors for light duty trucks that don't require a radiator like the ones mounted on commercial trucks. I'm guessing it's for cooling the oil.
Old Jun 12, 2007 | 07:46 AM
kimminau2's Avatar
kimminau2
try this
http://www.bossair.com/pto.php
or
http://www.vanair.com/
there are others
Old Jun 12, 2007 | 08:00 AM
SouthTexasDiesel
I've been looking for some smaller than that. The lightest model avaliable from those 2 dealers is over 300 lbs. And they all still require a cooling system. I'll probably end up buying an electric system, those look like they cost a pretty penny.
Old Jun 12, 2007 | 11:23 AM
thelogster's Avatar
thelogster
Here is another use for the PTO.
http://realacpower.com/
Old Jun 12, 2007 | 01:17 PM
PHWLEE's Avatar
PHWLEE
For the main part, manually driven air compressor pumps found on commercial vehicles will tend to be belt driven and incorporated into the engine drive belt such as an a/c compressor or the power steering pump. They will have automatic purge valves which will purge out the excess pressure since it is creating pressure constantly as long as the engine is running. This allows for constant availability of energy rather than having to go into PTO for power.
fisherman_chuck
Dec 31, 2016 11:48 AM
harvtown
May 21, 2015 03:12 PM
f350fixaliter
All Things Towing
Mar 9, 2015 08:07 PM
mando jake
Offroad & 4x4
Aug 11, 2009 12:15 AM
Monsta
Mar 12, 2002 09:39 PM
