Sponsored by: Real Truck
Voltage Regulator INSIDE alternator?
Old Jun 11, 2007 | 02:31 PM
RXevolv's Avatar
RXevolv
I was told this is the case. My PSD is surging up to about 16-17 volts, and I'm trying to fix this.
Does anyone know about this?
Old Jun 11, 2007 | 02:52 PM
msgtg's Avatar
msgtg
What year? Which motor?
Old Jun 11, 2007 | 02:57 PM
redford's Avatar
redford
FTE Leadership Emeritus
Yes, Ford has been using internally regulated alternators since sometime in the 80's or so, maybe earlier.
Having said this, the voltage surge may not be the alternator (or alternators). One of your batteries could be having a problem, causing the incorrect voltage reading, or a ground may be loose somewhere, also causing an incorrect reading.
The surge in voltage means you do have a problem, just be careful about declaring what the problem is without doing a little troubleshooting first.
Old Jun 11, 2007 | 05:11 PM
krewat's Avatar
krewat
Pretty sure the regulator is on the back of the alternator and easily removed (as long as the screws didn't corrode too much).
And like redford said, make sure it's really the alternator/regulator first.
One thing I've noticed about Ford alternators (the 3G) with their regulator.
If you have a bad diode (or more than one) in the alternator itself, it'll freak out the regulator and sometimes cause it to peak like you're seeing.
I've had it do this myself on my '96 t-bird.
- Alternator was pegging the voltage randomly.
- Changed the regulator.
- Still happened a week later.
- Changed the alternator for a "rebuilt", used old regulator, still in the car working 5 years later.
My '96 t-bird uses the same regulator as my 2001 V10.
Old Jun 11, 2007 | 10:49 PM
RXevolv's Avatar
RXevolv
Update
Well, I pulled the alternator (1999 PSD f250), and took it apart. I checked all 8 diodes, which checked ok. I then noticed that the two leads which follow the copper coated shaft. One of the leads was a little off, and was machining itself down, leaving a lip which went onto the inside portion of the alternator shaft.
I reshaped it, and took off the black residue on the copper.
Tomorrow I will reinstall the alt and see what happens!
Old Jun 12, 2007 | 05:05 PM
RXevolv's Avatar
RXevolv
New update.
Put the alternator back in after the rebuild, and the truck runs perfectly now. The voltmeter in the truck is displaying where it should.
This could have been a very expensive fix.
jle70
Dec 12, 2016 06:44 PM
ETKMS
6.4L Power Stroke Diesel
52
Nov 24, 2011 10:15 AM
kilaman
Jul 18, 2011 10:02 AM
Grunt0311
30
Dec 30, 2005 10:08 PM
