Poor mileage, real answers please....
I just read a thread where a guy was complaining about getting "only" 385 miles per tank of fuel. How about 220 per tank like me? (about 10.5 mpg)
What gives here? I have done and/or checked the following:
New fuel filter, new air filter (stock), ran several tanks of diesel-kleen, lock out hubs are NOT engaged, Little A/C use, RPMs UNDER 2000, 90% highway driving (I live just off the highway), stock tires, dissconnected EGBV tube from manifold (clogged badly), unplugged EGBV sensor from base of turbo, don't tow, no heavy loads, tried several brands of diesel, no codes and only "street" SCT chip programmed (mileage actually improved slightly after this flash). Also, but not related directly, I have flushed and changed tranny fluid, filter, coolant, oil and filter, rear and front diffs. Trying to be a "responsible owner". Highest mileage I have gotten is 15.
SOOOOO Boys and Girls, lets hear some good things I need to check, since my buddy gets better mileage with his V-10 flatbed towtruck.
I bought a diesel for the improved mileage, it's not happening and it's getting old.
*As a note, I have only had the truck for 3 months.
Leaking boots?
Low tire pressure?
Tried to go with 5w40 synthetic yet?
How are you calculating your mileage? Filling up to the neck, or just to when the pump clicks off? There is typically 4-6 gallons of room between the pump click and a truly full tank?
Tailgate up or down? "Up" increases mileage, contrary to you would want to think.
Have you dropped the tank to inspect the float and sending unit (can be done at the same time when doing the hutch and harpoon mods)?
Low tire pressure?
Like said above, check all intercooler tubing boots, see how badly your up pipes are leaking, and put a new ebps tube, and sensor in there, its part of the fuel mapping process. Do you have any gauges? That could help determine whats going on with your truck. However, my up pipes are leaking pretty good and i average 15 with 285 tires, and 8500# everyday weight, 80 hp tune........ How does the truck idle? Does it perform well? Stumble at all? More details on the motors performance etc would be good
Thanks guys, I have pressurized all IC boots and no leaks, tires are always up to spec, fill tank to the neck always, EGBV tube is clogged solid and was just unscrewed from the sensor and the sensor in a zip-lock bag near the HPOP unit. Not sure about float status in tank, but that would be irrelevent since I fill to neck each time, then calculate mileage. (fuel to fill)
Gear ratio is 3:73 (or whatever is below 4:10)
I have no issue re-piping the EGBV tube and plugging in the turbo0base sensor, but I have been told and read many trheads that say dissconnect and leave it.
I think your confusing the EBPV with the EBP Tube and Sensor. Unlike the EBPV the EBP Sensor and the tube you cleaned out should be inplace and operating correctly or the PCM goes into limp mode ergo crappy fuel economy. The Exhaust Back Pressure Sensor is at the top of the tube you removed.
I can reach 300miles/tank. But I'm not happy with it, I would like to see these 17 whatsoever mpg's, some others are saying to get in the city.
So I'm happy to see that there's somebody else with worse mileages
You saved my day
It has been the same all the time (13.5 - 14.0) since I got this truck. With or without chip. Heavy or light gas foot. Donno what's the problem. My wife was driving it like 3 days in a row, then it got this 14mpg for that tank!! So this has something to do with, who is driving
I have done the Cold Air, CCK, Chip, all the filters new etc. No changes, all the money wasted
I then unplugged the connector on the base of the turbo below the heated unit.
By the way, the truck runs great, just crappy mileage.
Ok, so what do I connect or dissconnect? I am comfused because there were several threads saying to just bypass that clogged manifold tube for BETTER mileage.
No codes, no check engine lights, everything else is ok?
Check this thread maybe it's makes more sense to you than I do.
https://www.ford-trucks.com/forums/6...light=ebp+tube
