7.3 runnine bad
Old Jun 11, 2007 | 08:37 AM
4drf350's Avatar
4drf350
Question 7.3 runnine bad
Hello everyone: I have a 1994 7.3 an I was driving it on a family trip an I was about 300 miles from my home an it started to run real bab I took it to the ford dealer an they say I have bad motor my # 2 cynilder had only 150 psi the others were at 300 psi . How do you check the conpresion on a 7.3 does anyone know , I am getting lots of blow be into my cracnk case an I am seeing lots of blue smoke coming out of am pipe . If I have a bad motor were is a good place to get a new one an what is the price ? Rick
Old Jun 11, 2007 | 10:24 AM
79F150EFI's Avatar
79F150EFI
Having low compression doesn't tell you why. You could have an injector not seated leaking oil into the combustion chamber burning causing low compression and smoking, and it would add pressure to the crankcase. Well, it is possible...
You should verify the compression test and do a leak down test. If it ran fine and all of a sudden started this it probably isn't a "bad motor". That would signify the block is so worn that it is leaking passed the rings. I would venture to guess that you have another problem since it happened all of a sudden.
Snap-on has compression testers and leak-down testers that fit our engines. If you don't want to spend snap-on's prices, and I don't blame you, others have the same tools as well. I haven't had good luck with harbor freight's compression testers or leak down testers. They were way too cheap and didn't work accurately. Although we can all take random guesses, the only way to find out what is wrong is to run these two tests.
Old Jun 11, 2007 | 11:19 AM
4drf350's Avatar
4drf350
Thank you I will see about haveing the test done again, how can I tell if the did it at the Ford dealer in the frist place. Rick
Old Jun 11, 2007 | 11:45 AM
tjbeggs's Avatar
tjbeggs
How much did your bill come to? a compression test requires removal of the valve covers. so your bill should reflect that.
Old Jun 11, 2007 | 12:06 PM
4drf350's Avatar
4drf350
The bill cam to about 270 dollars , but when I was looking at the valve covers if looks like the were not removed because I can still see the that the bolt have some black on them that has not been rubbed off
Old Jun 11, 2007 | 12:41 PM
tjbeggs's Avatar
tjbeggs
Well from the sounds of it I would say they did do it. usually if they are going to tell you that you have low compression they will just say you have low compression and not actually give you numbers. But I would get a second opinion and a leak down test need to be performed. It could be the rings are worn, piston cracked, head gasket, vavle issue, injector issue. so they need to do a leakage test to find out where it going.
Old Jun 11, 2007 | 12:43 PM
tjbeggs's Avatar
tjbeggs
And just to verify this is a powerstroke engine and not and IDI right? electronic injectors, turbo, wiring everywhere. if its a 94 PSD it should be a 5sp and not an auto.
Just making sure to be sure we are talking about the right engines here.
Old Jun 14, 2007 | 08:56 AM
4drf350's Avatar
4drf350
Hello again sorry for not getting back to you. I have the 7.3 idi I do not have electronic injectors an I have a auto tranny . Rick
Old Jun 14, 2007 | 10:01 AM
tjbeggs's Avatar
tjbeggs
Well then since you have the IDI your valve covers don't need to come off to check compression. But I would still get a second opinion. Let us know what you find out. Those engines sometime have valve guides that go bad too so that could be your issue. Once you get your second opinion post here then post your findings one forum lower. Those guys know more about the IDI's
Old Jun 14, 2007 | 10:40 AM
4drf350's Avatar
4drf350
Thank you I will go an do that an get beck with you , I have a Search & Rescue conf. here for a week or so but I will get it done an let you know . Thank you agian. Rick
