Replacing Oil Cooler Seals
Old Jun 10, 2007 | 10:55 AM
The Grinch's Avatar
The Grinch
Question Replacing Oil Cooler Seals
I am replacing the oil cooler seals on my '95 PSD. They are leaking like a siv. Is there any reason to replace the oil cooler and the end caps also? I live in the rust belt and wonder if the end caps and the oil cooler corrode and whether it would be worth the money to just replace the whole oil cooler assembly? What do you think? Anyone done this and found they needed to replace everything?
Old Jun 10, 2007 | 11:31 AM
Cuda_jim's Avatar
Cuda_jim
Here's a link for more info:
https://www.ford-trucks.com/forums/6...50-diesel.html
You posted in that link too, are you just now getting around to fixing it? The end caps can rot out and leak like you suggested. If you suspect that to be the case you might want to replace the whole thing. Big $$ tho.
Old Jun 10, 2007 | 03:00 PM
The Grinch's Avatar
The Grinch
Yes, just getting around to it. I have had other things on the plate. Things the wife wanted me to finish. As for cost, it is all cheaper doing it myself, right. Just seems to take a bit longer!
Old Jun 12, 2007 | 04:37 PM
mozz's Avatar
mozz
If there isnt any damage to the caps then just replace the orings. WORD of advice. DO NOT follow the haynes manual instructions for replacing the orings. The manual says to place the outer rings in the caps before pressing them back on. This is dead wrong, you will cut the rings this way. Place both sets of rings on the oil cooler then press the caps on.
Old Jun 12, 2007 | 06:08 PM
Action4478's Avatar
Action4478
This may help....http://community.webshots.com/album/93028687WtvRkH
Old Jun 20, 2007 | 07:26 AM
The Grinch's Avatar
The Grinch
Thanks! the parts go on on Friday. What should I use to lube the O-rings? Oil or a grease?
Old Jun 20, 2007 | 02:01 PM
Cuda_jim's Avatar
Cuda_jim
Either will work. I use the white lithium grease just cuz it's handy.
Old Jun 20, 2007 | 08:55 PM
powerstroked162's Avatar
powerstroked162
So that cooler comes from the factory aye?? I have never noticed it before
Cowboy Steve
Old Jun 21, 2007 | 12:00 PM
The Grinch's Avatar
The Grinch
Yep. Funny how you learn your truck has all kinds of parts on it good for haulin' when the parts start leaking. I would rather not know and just have them work! BTW, incase you want to know, parts total for end caps, new seals and gaskets, and a new cooler was just about $500. I don't want to have to do this again for a long while.
madhatt
Feb 25, 2014 04:30 PM
ExFire
Mar 4, 2013 11:43 PM
unixadm
Feb 11, 2008 10:20 AM
