Do I Really Need Welting ??
Old Jun 10, 2007 | 08:56 AM
houghda's Avatar
houghda
Ok, opinion time again. remember my 56 is not a show truck. I want to bolt the rear fenders directly to the bed sides without welting. Will this become a rust garden? Cant I just put a little seam sealer in there? Or maybe just bare?
I searched old posts and couldnt find this topic..........
Any and all input appreciated.
Old Jun 10, 2007 | 09:01 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford put the welting there for several reasons. It keeps water from entering between the fender and the bedside. It also prevents the metal from rubbing together. That will cause paint chips and squeeking.
Old Jun 10, 2007 | 09:23 AM
bobj49f2's Avatar
bobj49f2
If you don't want to use the welting I would think you could get away with using a good quality sealer. They didn't have the sealers we have today back then or else I bet they would have used them, it would have been a lot cheaper to squirt a bead of seam sealer in than have a piece of welting cut and layed in. I wouldn't just bolt metal on metal, I'm sure you'll get a lot of rubbing leading to squeaks and eventually scraped metal and rust. You could also use a good foam ribbon type sealer, this type might keep it's form better than a sealer from a tube.
One thing to keep in mind, especially if you're going to apply the sealer and then paint the truck, buy a sealer that is paintable. If you use a silicone based sealer read the label, most are not paintable and you'll end up with mess. It will cause fish eyes in the paint around the area you applied the sealer and anywhere you touched the truck with contaminated finger. You'd be amazed how easy silicone will get around.
Old Jun 10, 2007 | 09:30 AM
fergusonicford's Avatar
fergusonicford
Dave, if ya want, I can send you the welting I saved when I removed my rear fenders. There is nothing wrong with it; I just bought new..you know my email address.
Old Jun 10, 2007 | 09:37 AM
ALBUQ F-1's Avatar
ALBUQ F-1
If the welting was that woven "army belt" type of stuff, it is great at absorbing water after a couple years in the sun, and making good metal into rust. Maybe someone is making it in a modern rubber now? I'd vote for using welting and then sealing the seam with a paintable sealer to keep water and dirt out.
Old Jun 10, 2007 | 12:50 PM
NumberDummy
Painting your truck with 2 stage clearcoat paint? Then stay FAR away from silicone. Don't spray it near the paint, use no silicone based products on the paint. Silicone will strip the clearcoat right off!!!
Old Jun 10, 2007 | 01:33 PM
houghda's Avatar
houghda
That wouldnt be good!
You are saying that even if my truck is already painted that silicone will damage the clearcoat?!
Old Jun 10, 2007 | 03:13 PM
imlowr2's Avatar
imlowr2
I've seen people using very thin neoprene rubber and putting that in between the bed and fender. When you look at it, it appears there is no welting, but you still have waterproofing and resistence from scratching. I believe places like Home Depot sell rolls of the rubber. I've even talked to guy who cut bicycle inner tube rubber and put that in, then trimmed with the excess rubber with an exact knife. (Need to be careful you don't trim into the paint job.)
Old Jun 10, 2007 | 03:45 PM
NumberDummy
YES
stay away from any silicone based products!
Do not spray silicone near clearcoat / do not use a silicone based wax on clearcoat.
Otherwise....
Welting = neoprene welting is available. I bought several yards of it from an ad in Hemmings several years ago (from Bill Hirsch?) for my 1934 Packard.
Old Jun 10, 2007 | 05:32 PM
abe's Avatar
abe
The '56 (from my knowledge: '53-'56) did not have welting between the rear fenders and the bed sides. There was welting between the front fenders and the cowl, however.
In keeping my truck as close to stock as possible, I chose not to put the welting at the rear fenders in 1998. There is no rust there. I do not notice any squeeks. In the 44 years from production to my trucks rebuild, there was not a lot of rust in that area. There was a lot of rust in other areas but not between the fender and the bedside.
Its up to you.
Old Jun 10, 2007 | 06:15 PM
cal401's Avatar
cal401
How about the adhesive-backed rubber sheeting that is used for roofing? I've seen it in 36" wide rolls. I don't know if comes in narrower widths.
Cal
Old Jun 10, 2007 | 06:17 PM
imlowr2's Avatar
imlowr2
I just went through several pictures of trucks and either they painted the welting or most of them I saw are running without it. Here's an article I found which might help you guys.
http://www.classictruckshop.com/welting.php
http://cgi.ebay.com/ebaymotors/FORD-...spagenameZWD1V
Old Jun 10, 2007 | 07:48 PM
Kusto's Avatar
Kusto
If you do not want to use welting, another option would be to weld the fenders to the bed side and smooth the seam. This is what was done to my truck by the PO but I don't know if there are any down sides other than having to grind them off to replace or replace the entire side and fender at once.
Old Jun 10, 2007 | 08:55 PM
nutinbutford's Avatar
nutinbutford
Was the welting used only on pre 70's trucks? Not sure I've seen it on the Flareside models after the 50's models.
Old Jun 10, 2007 | 09:26 PM
theGman's Avatar
theGman
I've used some stuff like that from Lowes and it worked fine for me. Looked cleaner than the old welting.
