Missouri Chapter Join Chapter , Leader:77&79F250
Dyno Results
Old Jun 13, 2007 | 02:00 PM
  #31
SR_Crewchief's Avatar
SR_Crewchief
Perhaps
Old Jun 13, 2007 | 07:55 PM
  #32
6L PWR's Avatar
6L PWR
Originally Posted by SR_Crewchief
Compound? Has anyone considered duals, as in parallel? One dedicated to each bank? I'm presuming that since Banks has done this with the Duramax it is also feasible on a Powerstroke. Depending on plumbing clearances of course.
No, sequential. In a sequential type, the engine uses the smaller turbo at lower engine speeds to provide power early in the powerband, then as the engine moves up in speed and reachesa certain boost, the larger turbo kicks in and both pump air into the engine. In a compound setup, two different sized turbos feed off one another to do the job of one turbo. They work in series. Yes, therehave been some that looked into striaght twins, but, space is definately a limitation in the 6.0. Hard to plummb twins into the intercooler and back into the intake.
Delivered psi looks good. But, what is the rail pressure like at WOT? At the power range your running your probably not having an issue with starving the injectors at high rpm's.
If the rail pressure drops, so too will the feed pressure somewhat. Mine's not budging, yet. We'll see when the bigger injectors come along. I know some guys running 475cc injectors that just replaced the stock HFCM with a higher flow pump and changed to a bigger pickup and that's done it for them. I still need to drive on the street and tow, so I don't plan to go that big.
No machine work for fire rings? Sounds more like a reenforced performance headgasket. how much boost is this supposed to hold I wonder?
Basically, yes. Supports up to 65psi boost. About as much as the stock bottom end can handle anyway.
Has anyone developed a bolt on cam/gear to deal with the gear backing off under high rpm's?
Yes, but my pocket book isn't quite that deep, yet. I'm still waiting for Publisher's Clearing House to drop off my first check.
Old Jun 13, 2007 | 09:57 PM
  #33
SR_Crewchief
Know the feeling. Took real hard look at parts I'd need to make a reliable/streetable 500hp in my Cummins(99 VP44 24v)....10 grand is a good start before the supporting machine work.
last5oh_302
2004 - 2008 F150
13
Sep 10, 2007 05:21 PM
6L PWR
Jun 11, 2007 11:31 AM
soldmyta
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Oct 3, 2003 04:55 PM
Silver Streak
32
Aug 12, 2003 06:02 PM
MrMotorsport
Feb 27, 2002 01:53 PM
