Computer Chips & Tuners
Chip advice
Old Jul 25, 2002 | 07:44 PM
dayseizer's Avatar
dayseizer
Post Chip advice
I have a 91 F150 5speed manual, 302. I just had the engine rebuilt, larger valves, a crane cam (#13002), smoothed intakes. Nothing crazy. I put 24# injectors in, thinking "it doesn't matter, the computer will compensate." After listening to a surging idle, smelling the rich exhaust, and failing to smog - I started to think "oops."
From what I'm reading, it seems the computer assumes it has a certain size injector, which I think was supposed to be 19#. So I think I have three choices at this point -
1) put stock injectors in (lots of unbolting and bolting - $250 for the set)
2) get a recalibrated MAP sensor (not sure what they cost - but I get the feeling I'll be even worse off in the end - and no one will be able to fix my truck)
3) get a chip (no unbolting, about $300)
Couple questions:
1)Does anything I've said make sense? You're talking to a carb guy - this computer thing is uncharted territory for me.
2)What benefits could I expect from a chip - I'm not looking for any kind of crazy performance, I need enough reliable power to haul a camper and two big motorcycles around the country at interstate speeds.
3)How do I know if my truck is MAF or speed density? It seems to be an important thing to know....
Thanks VERY much in advance for any advice or help...
- dazed
Old Jul 27, 2002 | 05:55 PM
FTE Ken's Avatar
FTE Ken
Chip advice
In a situation such as yours the biggest benefit of a chip is getting the driveability issues under control. Given the changes, its suggested you get a dyno pull of the engine done so you can supply that to us along with a custom sheet. Its the best way to insure the chip will give smooth performance. Your truck is speed density. 1994 is the year F150's changed over to MAF. The chip will give a performance increase but I can't give an exact number given your changes.
Old Jul 28, 2002 | 05:16 PM
FTE Ken's Avatar
FTE Ken
Chip advice
misterfisher
May 10, 2017 10:27 PM
Bubba Jones
43
May 18, 2016 11:49 AM
Bubba Jones
May 12, 2016 11:43 AM
Nick Pigglet Curtis
13
Feb 5, 2016 05:56 PM
Tsaven Nava
Sep 7, 2004 12:54 AM
