Steering wheel shake
Old Jun 9, 2007 | 03:21 PM
kuzindwight's Avatar
kuzindwight
My steering wheel has developed a pretty good shack. Is there a shim or something in the wheel that I have to change out or adjust.
I'm wondering if something is getting ready to break loose. The Chiltons doesn't address an issue like this that I can find.
Thanks, Jay
1984 F250 Diesel
Old Jun 9, 2007 | 03:25 PM
speedrdr's Avatar
speedrdr
would be good to check all the steering connections to make sure they don't have a lot of extra slack. also the tire(s) may be out of balance causing that shake. my p/s pump is going out and i've got a semblance of a shake there. may check that as well.
speedrdr
Old Jun 9, 2007 | 04:50 PM
tbone91's Avatar
tbone91
Is there a lot of "slack" in the steering while driving? Does it pull to one side or happen more/less when you apply the brakes? Do you hear any noises while turning?
Also, check both front tires carefully for anything unusual, like a bulge, there's a remote possibility it could be a broken cord.
Old Jun 9, 2007 | 08:04 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Is this like an all the time thing or just under certain conditions?
Is your truck a 4x4 or two wheel drive?
Tires that have a bad wear pattern from a bad alignment.
Tires out of balance
Tires with a defect like broken cords, knots, chunks missing.
Tie rod wear.
Ball joint wear.
Old Jun 10, 2007 | 12:15 PM
kuzindwight
The problem is in the steering column.
The tires are newish and the brakes are good. The steering wheel has slack in the upper half just below the shifter. The lower half of the column is solid bolted to the truck, no shake there.
I just can't figure out looking at the column how to get into it to replace shims or tighten something up.
Thanks, Jay
blowin smoke
2004 - 2008 F150
13
Jan 14, 2008 07:38 PM
bodysaffa
Apr 4, 2002 11:15 AM
jaye
Aug 11, 2001 09:09 PM
