Computer Chips & Tuners
Which tuner/chip???
Old Jul 30, 2002 | 03:29 PM
jncrgsc's Avatar
jncrgsc
Post Which tuner/chip???
I have a 99 PSD which I use primarily for hauling a slide-in camper(2500pounds). I am interested in re-programming the chip for better performance and hopefully better mileage. Even on moderate hills, I have to shut off overdrive when using cruise control to stop the frequent shifting in and out. Any suggestions will be much appreciated.
Old Jul 31, 2002 | 09:22 AM
FTE Ken's Avatar
FTE Ken
Which tuner/chip???
A switch chip, such as the Diablo Delta, has the advantage of being able to flip between horsepower settings on the fly. The down side is the installation headache (the Powerstroke trucks are the worst next to the Powerstroke vans and the Rangers/Explorers are the easiest). This allows you to monitor EGTs and switch to the lower HP setting if you're getting high EGTs. This is a major plus for towing.
The Microtuner has the disadvantage of not being able to flip on the fly but it has no installation headaches (plug into the ADL port under the steering wheel, floor the on-screen instructions and 5 minutes later you unplug it). This also lets you return the truck to stock quickly and it leaves no codes in the computer. The biggest plus of the Microtuner is that it always works. No ECU code mismatches, no having to reprogram your chip if the dealer reflashes your computer.
We offer either choice: the Microtuner for fool-proof ease of use and the Diablo Delta for safe on the fly switching of programs.
Old Jul 31, 2002 | 09:25 AM
FTE Ken's Avatar
FTE Ken
Which tuner/chip???
quality ford
Apr 24, 2008 11:13 AM
That_Just_Happened
16
Aug 18, 2007 09:45 AM
sparke454
Jan 13, 2004 09:50 PM
Jimmygunz3
Jun 17, 2003 05:18 PM
dirk
Jul 14, 2001 01:11 AM
