EBP???
Jan 17, 2012 | 06:42 AM
EBP???
What should the ebp reading be on a scan gauge ll ?
Jan 17, 2012 | 06:43 AM
EBP, MAP, and BARO should read within .5psi of each other at KOEO (key on engine off)
Jan 17, 2012 | 06:58 AM
What should it be running down the road?
Jan 17, 2012 | 07:02 AM
Quote:
Originally Posted by
j-bar
No set value. It will go up and down as more/less demand is put on the turbo. In a manner of speaking, EBP is reading turbo drive pressure, which varies with vane position/engine demand.
Jan 17, 2012 | 07:13 AM
Truck seems to be down on power like a truck with no turbo was just wondering.
Jan 17, 2012 | 08:34 AM
Ebp reading would also be off a bit if you're running an aftermarket exhaust with no cat/muffler.
Jan 18, 2012 | 04:04 AM
EBP has a correlation to VGT position and MAP. Have you verified the variable vanes in the turbo are not stuck?
The higher the VGT numbers, generally the higher the EBP in relation to the MAP.
I wish there was a setting on the scangauge that showed EBP as a ratio of MAP to EBP. That seems more useful under any combination of load/RPM/MPH.
Jan 18, 2012 | 04:52 AM
Can the Edge CS read EBP?
Enez
Jul 23, 2018 07:35 PM
BradyHorton6.0
Feb 22, 2016 08:17 AM
s_focht
Jun 25, 2007 07:59 AM
yukonsly
21
Apr 24, 2007 08:07 PM
Black88GT
Jul 18, 2004 08:16 AM
