Sponsored by: Real Truck
Upfitter Switches
Old Jun 8, 2007 | 10:51 AM
grady24's Avatar
grady24
Upfitter Switches
Does anybody know if the upfitter switches have power when the ignition is off? I'd like to power some accessories while the truck is off.
Old Jun 8, 2007 | 11:13 AM
marcussen's Avatar
marcussen
they only have power with ignition ON.
Old Jun 8, 2007 | 11:32 AM
rwilimo's Avatar
rwilimo
This is of course modifiable
Old Jun 8, 2007 | 12:01 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
ANYTHING is modifiable!!! Will it ever work again??? Maybe!
Old Jun 8, 2007 | 04:06 PM
davhut's Avatar
davhut
the Upfitter relay assembly has a feed to the switched power source by default. Can't remember the wire colour off hand however you need only locate that wire (small gauge) and connect it to a source which is hot all the time. Of course, you would also need to supply a always on hot for the load(s) as well. My suggestion would be to only place the switches you wnat to be active at all times on the always on power feed (make sure it has the rated capacity to run what your trying to run) and leave the rest connected to a ignition on only power source.
Old Jun 8, 2007 | 08:31 PM
gibster's Avatar
gibster
need a little help
installed oem fog lights but don't seem to have any power to orange tag wire by fuse box, any help would be great
06 250 5.4 3.73 9200gvw etang r/t
bigcountry1009
Oct 27, 2014 05:09 AM
Moon's Dad
Apr 29, 2011 09:03 PM
kpmalone
Mar 20, 2010 05:10 PM
QDWilliams
Electrical Systems/Wiring
Jan 1, 2009 06:02 PM
tim241
Oct 11, 2006 03:07 PM
