got something wet??
Old Jun 7, 2007 | 08:11 PM
barnbuoy's Avatar
barnbuoy
got something wet??
did a couple quick preasure washer squirts under the hood on the driver side today.
getting ready to peal the wrap off the hot side turbo tube, so i was knocking some of the heavy dust off of the tube and surronding area.
started the truck and pulled it out of my way and left it to warm up for a few minutes and when i came back to it...it had stalled.
restarted...(barely) and found a very rough run condition...and a service engine lite.
kept it running with lots of gas pedal finesse and finally came back to normal.
took it for quick ride....started doing it again...so i babied it back home and just as i pulled back into the driveway--problem cleared up again. and so far has not reaccured...
any ideas what i did????
Old Jun 7, 2007 | 08:15 PM
Smokin''s Avatar
Smokin'
Smokin
Well anything electrical...like your wiring harness or alternator would be my first thought. Even if you didn't spray in that area directly...
Old Jun 7, 2007 | 08:18 PM
Uzumati's Avatar
Uzumati
Check the ICP sensor toward the front of the driver side head (Purple Top connector) it may have gotten wet.
Another spot to check is the connector and brass looking nut on the back of the IPR. If water knocked that nut loose it can cause rough running and stalling or if wayer got in the connector it could too. The IPR is just below and to the right of the fuel drain valve and under the oil temp sensor.
Old Jun 7, 2007 | 08:26 PM
barnbuoy's Avatar
barnbuoy
hey thanx for the quick replys
dark right now but first thing in the A.M.
thanx again!!!!
Old Jun 7, 2007 | 08:31 PM
Smokin''s Avatar
Smokin'
Smokin
I've been wanting to de-grease my motor, but i'm too chicken I don't want to worry about getting things wet and causing problems.
Old Jun 7, 2007 | 08:35 PM
Uzumati's Avatar
Uzumati
I wash mine once a week (old habit from the fire station) with a garden hose and greased lightning and never had an electrical problem.
1. bag alternator and PS pump
2. use dielectric grease on all of the connectors.
Old Jun 7, 2007 | 11:58 PM
SpringerPop's Avatar
SpringerPop
Can I get an AMEN?!?!?
For those that missed what Alan just said,
GO UP ONE POST AND RE-READ IT!
Gonna' save you some trouble in the long run.
Pop
Old Jun 8, 2007 | 05:30 AM
barnbuoy's Avatar
barnbuoy
yup--i commonly hose my gassers and my BIG diesel ALL THE TIME! i never cover anything! i simply avoid areas that i know will give me trouble.
this truck is new-to-me. first time i've tried it...
i should have enough light in a couple hours to start an investigation.
sounds like alan has the low-down?
cept i dont know what the IPR is.....or exactly where....
sorry dont mean to be stupid--7point3's are all new to me.
Old Jun 8, 2007 | 07:14 AM
Uzumati's Avatar
Uzumati
The IPR is the Gold looking bolt in the center of the pic, The ICP is at the bottom and Purple on top
The ICP sends a signal to the PCM of what the pressure in the high pressure oil rail is and the PCM commands the IPR to either raise or lower it depending on need.
Old Jun 8, 2007 | 10:12 AM
barnbuoy's Avatar
barnbuoy
awesome! thanx a thousand times! well the problem seems to be gone....hmmmm.
went for a nice little test drive this A.M. and nothing.
Old Jun 8, 2007 | 11:41 AM
Izzy351's Avatar
Izzy351
I also clean my engine fairly regularly with Simple Green. Haven't had any issues...
Joe
