351C Stroker project
Hope that is better, sorry about the double post.
The distributor did not have a vac. advance. I was not involved that much in the dynoing.
24 advance is the max for the peak power. These heads are very efficient, so I knew it would be low. We started at about 20 & went up.
The engine was dyno'd on 91 oct. pump gas.
Originally Posted by TMI
Here we have a 351C stroked 4"
topped off with the CHI 2V heads and an Edelbroc air gap intake.
It should get warmed up tonight.
Comp Cam 32-250-4
What does Doctor Dyno "Dan" guess for HP?
Comp Cam 32-250-4
I need the rod length, and static Compression Ratio. Also Carb size and Bore.
I don't have that cam in my files, can you give me the specs: Advertised and @0.050" duration, lift, LSA, and ICL.
You can get the cam specs off of Summits website, just enter the number: CCA-32-250-4. Maybe this link will work:
http://store.summitracing.com/partde...4&autoview=sku
OK, got that. I set the ICL at 106 and ECL at 114 degrees.
Now I just need the Bore, Rod Length, and CR.
So quess how much a 351C weighs with CHI heads?
Here are a few links to some pictures & 1 video on the dyno
http://www.tmeyerinc.com/images/351C%20001.jpg
http://www.tmeyerinc.com/images/351C%20002.jpg
Video
http://www.tmeyerinc.com/movies/Kent%20dyno.MOV
Hope those links work.
Video
