351C Stroker project
Old 06-07-2007, 05:53 PM
TMI's Avatar
TMI
TMI is offline
Here we have a 351C stroked 4"
topped off with the CHI 2V heads and an Edelbroc air gap intake.
It should get warmed up tonight.
Comp Cam 32-250-4
What does Doctor Dyno "Dan" guess for HP?
Old 06-07-2007, 06:38 PM
53fatfndr's Avatar
53fatfndr
53fatfndr is offline
That looks awesome
Old 06-08-2007, 04:54 PM
TMI's Avatar
TMI
TMI is offline
Horsepower Peaks Peak CorrH 479
Average CorrHP 369
Peak CorrHP 481
Average CorrHP 369
Torque Peaks Peak CorrTorq 489
Average CorrTorq 456
Peak CorrTorq 488
24 degrees full advance
Old 06-08-2007, 04:56 PM
TMI's Avatar
TMI
TMI is offline
Horsepower Peak CorrHp 479
Average CorrHP 369
Peak CorrHP 481
Average CorrHP 369
Torque Peak CorrTorq 489
Peak CorrTorq 488
Old 06-08-2007, 10:50 PM
grclark351's Avatar
grclark351
grclark351 is offline
hey Tim, any chance of better a graph? the scales seem to be in a forgeign language and kinda hard to read at that.
24 degrees total timing, was that just an arbitrary number or did you do some 'sperimentin? what ignition? how much initial? any vacuum?
Old 06-08-2007, 11:33 PM
TMI's Avatar
TMI
TMI is offline
Hope that is better, sorry about the double post.
The distributor did not have a vac. advance. I was not involved that much in the dynoing.
24 advance is the max for the peak power. These heads are very efficient, so I knew it would be low. We started at about 20 & went up.
The engine was dyno'd on 91 oct. pump gas.
Old 06-13-2007, 07:31 PM
danlee's Avatar
danlee
danlee is offline
Comp Cam 32-250-4
I'm sorry that I missed this post. I've been preoccupied recently.
I need the rod length, and static Compression Ratio. Also Carb size and Bore.
I don't have that cam in my files, can you give me the specs: Advertised and @0.050" duration, lift, LSA, and ICL.
Old 06-14-2007, 01:39 AM
roger dowty's Avatar
roger dowty
roger dowty is offline
to me it looks like a very very solid 400 build but scaled up 1000 rpm. Any reason a stroked cleveland would spin better than a 400? Cam spec would be nice to know.
Old 06-14-2007, 11:48 AM
53fatfndr's Avatar
53fatfndr
You can get the cam specs off of Summits website, just enter the number: CCA-32-250-4. Maybe this link will work:
http://store.summitracing.com/partde...4&autoview=sku
Old 06-14-2007, 12:02 PM
danlee's Avatar
danlee
danlee is offline
OK, got that. I set the ICL at 106 and ECL at 114 degrees.
Now I just need the Bore, Rod Length, and CR.
Old 06-14-2007, 01:35 PM
TMI's Avatar
TMI
TMI is offline
So quess how much a 351C weighs with CHI heads?
Here are a few links to some pictures & 1 video on the dyno
http://www.tmeyerinc.com/images/351C%20001.jpg
http://www.tmeyerinc.com/images/351C%20002.jpg
Video
http://www.tmeyerinc.com/movies/Kent%20dyno.MOV
Hope those links work.
Old 06-14-2007, 04:58 PM
53fatfndr's Avatar
53fatfndr
Links work, sounds awesome!
Old 06-14-2007, 06:36 PM
danlee's Avatar
danlee
danlee is offline
So, what does that gauge say the weight is?
Old 06-14-2007, 06:52 PM
packlet's Avatar
packlet
packlet is offline
i read it as 417 lbs.
Old 06-14-2007, 07:17 PM
danlee's Avatar
danlee
danlee is offline
Now I see it. It is 417 lbs. I never was able to weigh my motor, but with a taller deck and heavier crank it is probably closer to 500 lbs than 400.
Quick Reply: 351C Stroker project
