1992 Ford f150 ac problem
Old Jun 7, 2007 | 12:49 PM
fordfinatic's Avatar
fordfinatic
Hey on my 1992 ford f150 with the straight 6 and the mazda 5 speed. I cant get cold air to come out of it. The system is charged to full capacity and the compresser is kicking on like it should. The only things i have noticed on it is that it doesnt have a fan shroud (never had since i got it) and the compressor kicks on and off alot when im attempting to have it on. Could there be a clog? or what?
thanks for all of your suggestion
Old Jun 7, 2007 | 08:51 PM
Ultramagdan's Avatar
Ultramagdan
What are your gauge readings?
Old Jun 7, 2007 | 10:35 PM
fordfinatic
about 40 psi from the low pressure side i believe
sorry man i dont know much about ac systems i just know how to recharge it haha and when im recharging it i stop it at 40 psi
Old Jun 8, 2007 | 11:14 AM
lsrx101's Avatar
lsrx101
Quick cycling of the compressor usually indicates a low refrigerant charge. Your 40 psi idea doesn't tell you anything, especially if you don't know what the high side pressure is. The cheapie low side gauge (it sounds like) you are using is worthless.
You really need a fan shroud for the AC to work preoperly. It keeps air pulling through the condenser instead of from the sides of the fan.
Put a fan shroud on it and rent a manifold gauge set from your local Auto Zone, Pep Boys, etc.
larg3n
15
May 24, 2023 08:16 PM
Junebug19
Texas Chapter
Jun 5, 2016 10:19 PM
1992FordF150Custom
Jan 31, 2011 10:07 AM
ford power 302
Engine Swaps
May 11, 2007 04:58 PM
ford150man
Nite, Nascar & Other Limited Edition Ford Trucks
Mar 26, 2007 06:09 AM
