1992 f150 engine swap
Old May 3, 2007 | 06:41 PM
ford power 302's Avatar
ford power 302
I got this 92 f150 with a str8 six in it is there any modifications i have to do to put a 331 in it?
thanks
Old May 3, 2007 | 06:47 PM
taisa899's Avatar
taisa899
assume you mean 351??
Jim
Old May 3, 2007 | 06:49 PM
taisa899's Avatar
taisa899
cancel that saw your other post. Where di you want me to start? With getting it in the truck or getting it to run? There's actually alot you have to do
Jim
ford power 302
its a 302 stroked 331 is there any modifications i have to do to the motor mounts to get it to set in there
Old May 3, 2007 | 06:51 PM
taisa899's Avatar
taisa899
you're gonna have to remove the 4.9 frame mounts and replace them with 5.0L frame mounts. These are the mounts the motor mounts bolt to
jim
Old May 3, 2007 | 06:53 PM
ford power 302
so the 5.0 motor mounts will bolt right into the frame in the exisiting holes
Old May 3, 2007 | 06:54 PM
taisa899's Avatar
taisa899
no that's what I'm talking about. You need the frame mounts. they bolt to the frame and then the motor mounts bolt to them.
Jim
Old May 3, 2007 | 07:00 PM
ford power 302
i think im getting this im a lil new at this so you take out the 300 frame mounts install 5.0 frame mounts
now does the 5.0 frame mounts bolt right into place
Old May 3, 2007 | 08:14 PM
taisa899's Avatar
taisa899
you got it. The 5.0 frame mounts bolt right into place to the rear of the crossmember that's in the engine bay
Jim
Old May 11, 2007 | 04:58 PM
Kemicalburns's Avatar
Kemicalburns
so are you going to run this motor carbed or efi?
ryan f150 4x4
1978 - 1996 Big Bronco
Jun 24, 2021 09:56 PM
Al9
User Gallery & Picture Display
Nov 22, 2016 02:26 PM
baverwolf
Sep 17, 2011 07:09 PM
Okiedokie
1997 - 2003 F150
22
May 28, 2011 06:30 PM
LopezD
New Member Introductions
Jun 19, 2007 02:21 AM
