Venting Sound
Old Jun 7, 2007 | 08:39 AM
mshostek's Avatar
mshostek
Venting Sound
02, 7.3 stock tranny, Automatic. A
Anybody ever hear a venting sound when their truck shifts from third to fourth when under a load? The sound is similar to the sound you get when when you quick disconnect an air hose that still has air under pressure in the hose (just not nearly as loud and crisp). No one I have talked to has ever heard such a sound.
Old Jun 7, 2007 | 08:48 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Do you have an open intake or do you have the stock air box?
Old Jun 7, 2007 | 09:18 AM
Izzy351's Avatar
Izzy351
I hear it often with my 6637 intake...
Joe
Old Jun 7, 2007 | 09:22 AM
FordTruckNoob's Avatar
FordTruckNoob
I have an open intake and I get that noise too.
Old Jun 7, 2007 | 10:38 AM
mshostek's Avatar
mshostek
I have installed the after market K&N so I guess I have an open intake. Is the sound normal?
Old Jun 7, 2007 | 10:55 AM
Texas Outlaw
Not a liberal...
Yes, it's normal. That is compressed air that is being forced back out through the filter. You're ok.
Old Jun 7, 2007 | 12:24 PM
mshostek's Avatar
mshostek
Thank you. It has really been freaking me out.
Old Jun 7, 2007 | 12:29 PM
Texas Outlaw
Not a liberal...
It did me too when I first installed my AFE. You can control it by easing up a little on the throttle just before the shift if it bothers you.
Old Jun 7, 2007 | 02:40 PM
RockyMtnRanger's Avatar
RockyMtnRanger
It's been said a zillion times here, but you might consider canning the K&N. It will not seal correctly and end up dusting your turbo or worse. You'll find a vast majority here will not recommend them.
Marty
Old Jun 7, 2007 | 03:42 PM
mshostek's Avatar
mshostek
which one would you recommend?
Old Jun 7, 2007 | 03:56 PM
RockyMtnRanger
You might do a search for "Intake system, Air filter etc." A lot of guys use the 6637 filter as I do. The AFE units are really good too. I'm sure others will chime in here.
Marty
Old Jun 8, 2007 | 09:26 AM
mshostek's Avatar
mshostek
Where do you buy the 6637? Is it a special order? Does it come with the ducting?
Old Jun 8, 2007 | 08:50 PM
JOE-M's Avatar
JOE-M
6637 is the filter number from NAPA. No it doesn't come with any duct work you have to build it yourself. It is only a bare filter. Now with all that said, if you have the K&N open element filter you should be OK. The problem K&Ns are the drop in filters with the stock air boxes still in place. The filters aren't the big problem it's the way they don't seal up well in the stock boxes and let dirt get by and "dust" the engines.
Joe
Old Jun 8, 2007 | 11:02 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Joe
I agree. Oiled gauze is oiled gauze. K&N, AFE, Airraid, S&B, etc. etc. are all using virtually identical filter media. It's the cheezy stock airbox that causes the majority of the problems.
Old Jun 9, 2007 | 08:04 AM
Izzy351's Avatar
Izzy351
Not so fast...
The below picture is from a K&N conical (open element) filter. I wouldn't use it either.
