Venting Sound
Old Jun 9, 2007 | 11:28 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Yep...that's the risk you take with cotton filters. I've run K&N, S&B, and an AFE element on my truck. They are all exactly the same. Given enough wash cycles the cotton will shrink and little pinholes will form in the media. Holes large enough that our turbos will suck the oil right out of them.
I will never believe, or agree that this is a problem specific to K&N, because I know that it is not.
Why do think I keep coming back to the 6637?.....it's the only one that I can trust to do the job.
Old Jun 9, 2007 | 12:19 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
I run the AFE and you can white glove test the inside of my intake tube any day. I have two filters so that when I wash and change one I can put a fresh one on while the other is being serviced.
In defense of the K&N, I ran a K&N open system on my '99 for two years and could never find any evidence of dusting. The guy that I sold it to is still running that set up or at least was the last time I saw him with the truck about 3 months ago.
Old Jun 10, 2007 | 10:32 AM
mshostek's Avatar
mshostek
So how do you buy and install the 6637? I keep hearing a lot of folks talk about them but it dos not look like a standard install.
Old Jun 10, 2007 | 10:46 AM
Uzumati's Avatar
Uzumati
www.fleetfilter.com look up a 46637. get a short (3"-4") piece of 4" exhaust pipe and rmove the top of the stock air box. Use the piece of exhaust to connect the tube to the filter and lay it in the bottom of the stock air box. Or you can remove the air box and fabricate a battery tray then just let the filter lay behind the battery and zip tie the IAT sensor from the air box to the master cylinder.
F350-6
Nov 4, 2014 07:37 PM
73 ford guy
Oct 25, 2013 11:07 PM
fordsbyjay
Nov 21, 2010 09:40 PM
jmaxe444
May 12, 2010 03:12 PM
tigerdude2001
May 31, 2002 05:12 PM
