fault code p1401
Old Jun 6, 2007 | 06:52 PM
pawpaw's Avatar
pawpaw
Welcome to FTE CheezKake.
Did you also have evap system trouble code/s, like a p0457, loose or leaking gas cap, ect, too????
Am I mis-reading, or missing, or mistakenly inferring something here, the way I read CheezKake's posting, a loose/faulty gas cap was causing a P1401 DPFE code & I don't think I've ever heard of a loose gas cap causing that code.
A loose or damaged gas cap sure can trip a number of evap system codes like a P0457, ect, though.
Blackwidow1, or CheezKake, for clarification of the record, so someone else reading this thread isn't confused about what all was done, can you post all the trouble codes you had.
Anyway, good to hear it's all put right & "your on the road again"!!!!!
Old Jun 6, 2007 | 07:04 PM
pawpaw's Avatar
pawpaw
Blackwidow1, or CheezKake, for clarification of the record, so someone else reading this thread isn't confused about what all was done, can you post all the trouble codes you had, or what was done to fix the P1401 DPFE code.
Old Jun 7, 2007 | 12:14 AM
CheezKake's Avatar
CheezKake
Smile
Sure thing...in all honesty, it's kinda weird how everything just showed up as a P1401...but, here's the list they gave us.
-EGR Temperature Sensor
- Open or Short Circuit Condition
- Poor Electrical Connection
- Failed EGR Temperature Sensor
- Blocked EGR Passages
-EVAP System Malfunction
- Loose or Missing Fuel Cap
- Saturated EVAP Canister
- Failed EVAP Vent Solenoid
- Failed Leak Detection Module
-DPFE Sensor High Voltage
- Open Circuit Condition
- Failed DPFE Sensor
-DPFE EGR Circuit High Input
-DPFE Sensor Circuit High
- Failed DPFE Sensor (EGR Pressure Sensor)
-Sub-Throttle Position Sensor Range/Performance Problem
-Diagnostic Module Tank Leakage (DMTL) Failure
- Faulty DMTL Module Faulty
-Fuel Tank Pressure Control System Function Problem
- Open or Short Circuit Condition Problem
- Failed Fuel Tank Pressure Control Solenoid
-Sub-TP Sensor Range/Performance
-Exhaust Gas Recirculation Flow Test Fault
- Check EGR Valve Function
- Check Intake Manifold for Carbon Blockage
-Heated Catalyst Current too High During Heating (Bank 1)
-EGR Valve Power Stage Short to Ground
- Failed EGR Valve
That's it, all 12 problems they gave us. Listed are the problems themselves, and the probable causes they gave us.
Old Jun 7, 2007 | 06:50 AM
pawpaw's Avatar
pawpaw
OK, good feedback CheezeKake, now I understand & as I finally suspected, you didn't have just one trouble code, but were simultaneously chasing a multitude of them.
In the future it would be helpful for anyone reading this tread & working more than one problem at a time, or having more than one computer trouble code, to post ALL the known code numbers, or problems, as this can often help a board give you a better more accurate interperation of your problem/s & maybe be able to suggest a shorter & more accurate trouble shoot.
Blackwiddow, the reason the trouble light didn't go out when you replaced the DPFE, was because you still had other problems.
The only way to know if the P1401 was fixed, would have been to rescan the computer for trouble codes & see if it was still there after the DPFE was replaced & the computers memory was erased.
You sort of went about it another way, by the DPFE substitution, in another like vehicle & when the DPFE worked ok in it, then CheezeKake probably suspected the new one was ok & you still had other problems.
Thats when I finally begin to wake up & suspect you were working other problems also.
This will help anyone with a P1401 trouble code & reviewing this thread, to not be confused and think by replacing a gas cap, they could fix a P1401.
Replacing the gas cap, fixed some of the remaining Evap System trouble codes you had, it had NOTHING to do with fixing the P1401 DPFE code. Replacing the DPFE sensor likely fixed that code imo.
For additional clarification, if you like & would post the parts you've replaced & the trouble code "Numbers" you were given, we could probably group them together & sort of give you & others with a P1401 code, that are reviewing this thread, an idea of how to form up & group your suspect list, when troubleshooting by computer trouble code.
Also we have a very good "Tech Info" thread, located atop this forums thread listing page. https://www.ford-trucks.com/forums/1...formation.html
Just some additional thoughts for clarification.
Last edited by pawpaw; Jun 7, 2007 at 07:32 AM. Reason: add tech info link, fix spelling
Sur4w
15
Sep 9, 2015 06:52 AM
cabo169
Feb 24, 2008 03:24 PM
piedmont
Aug 16, 2007 10:07 AM
grizz3000
Aerostar
Nov 26, 2006 12:43 AM
whjamesiii
Aug 1, 2006 07:39 AM
