down pipe
Old Jun 4, 2007 | 07:57 PM
wmiller's Avatar
wmiller
down pipe
I'm thinkin about puting the 3" down pipe on my 97'. How hard of an install is this? are some easier to put in then others?
Old Jun 4, 2007 | 08:26 PM
glasseater's Avatar
glasseater
it took a couple hours... more like 4-5 haha getting the old one out takes a couple of sawzall blades/batterys and a lot of twisting and turning to get it out.. to get the new one in you gotta bend the firewall out a bit by the tranny but besides that it's pretty easy... remember to put duct tape or something over the turbo to keep crap from getting into there... mostly metal shavings
Old Jun 4, 2007 | 08:45 PM
Neal 97 250's Avatar
Neal 97 250
I agree not too hard but takes some time and patience. cut in half and pull out from top and bottom. There is a flange 1/2 way down fire wall where floorpan and upper firewall meet and are tack welded. cut this flange about 3/4"deep down to firewall surface. And do it on both sides of where the DP will be. then bend it down flush with the Firewall and insert new one. I have heard of people "beating" the firewall with wood and/or sledge but I didn't have to do it. I am sure it would make more room but I don't like using hammers unless necessary.
Old Jun 4, 2007 | 08:51 PM
U.P. Builder's Avatar
U.P. Builder
I only had to bend the flange on the firewall over and it fit with plenty of clearance. I've head there can be quite a difference between trucks as far as where the engine and cab are mounted in relationship to each other. Mine had room but others may be tighter. Either way, it's worth the effort. The stock downpipe really sux.
Old Jun 4, 2007 | 08:53 PM
glasseater's Avatar
glasseater
yeah i used a crow bar with mine, just a couple good pulls and the new one fit snugly (not touching once it was all attached though)
Old Jun 4, 2007 | 08:54 PM
Neal 97 250
I agree with U.P. 100% well worth it. Remember...PATIENCE.
Old Jun 4, 2007 | 09:00 PM
ech0sh4y's Avatar
ech0sh4y
I have a 3" body lift and clearance is no issue... do they make bigger than 3" that would work on our trucks? Any beneift? Sorry to change topic!
Old Jun 4, 2007 | 09:03 PM
glasseater's Avatar
glasseater
guys are running 3" dp's with well over 500hp... i don't think it'll give you any benifit going to a 3 1/2 or 4" and by the way i don't think they make any TRUE 4" dp's... they start out at 3 1/2
Old Jun 4, 2007 | 09:06 PM
Neal 97 250
I have heard that they make one that is 3" out of turbo and enlarging 3.5" below firewall. You can always have someone do a custom job. Someone on here had BDP customize a '99-'03 3.5" DP and make it fit ours. Enough money and mods can get anything done.
Old Jun 4, 2007 | 10:00 PM
bigbadwolfe's Avatar
bigbadwolfe
if you have the money some one will do it for you i sure if you paid the right person you could get a 5inch D/P you know what they say money talks
Old Jun 4, 2007 | 10:16 PM
ech0sh4y's Avatar
ech0sh4y
would it even be worth it though? i'm planning on making 20000000hp any time soon =D
Old Jun 4, 2007 | 10:18 PM
Neal 97 250
I have thought about dual 3" DP's down to dual 5" out back(don't like stacks) would be cool. Then again enough money or engineuity will get you anything you want.
Old Jun 4, 2007 | 11:15 PM
bigbadwolfe
wmiller call dale at tymar he will set you up nice
Old Jun 5, 2007 | 03:18 PM
glasseater's Avatar
glasseater
be different and get headers that go to their own individual turbos and also dual intakes... why hasn't anyone tried that yet??
Old Jun 5, 2007 | 08:02 PM
c00nhunterjoe's Avatar
c00nhunterjoe
they make headers for duramaxs but not strokers, i have always pondered the thought of how more flow to the turbo would be but then i dont know how the loss of backpressure would effect it unless you were makeing a ton of power to start with
