Sponsored by: Auxito
4.6L modular engine spark plug replacement.
Old Mar 21, 2001 | 10:09 AM
tooch's Avatar
tooch
Help! How in God's green acres do you change the plugs on a 98 4.6L? Especially the back four! I got #1 and #2 out. It only took 45 minutes... Is this the reason that the dealer wants $600.00 for a tune up?
Old Mar 23, 2001 | 12:57 AM
knuckles's Avatar
knuckles
It helps to have a swivel spark plug socket & some swivel extensions.
$600 is a little steep. The rear plugs are kinda hard to get to, but they're not that hard to reach!
Old Sep 9, 2002 | 11:48 AM
RHODCO's Avatar
RHODCO
I've heard it's easier if you jack up the front end first.
Old Sep 10, 2002 | 07:56 PM
geoaigel's Avatar
geoaigel
You need a swivel spark plug socket. You can find them in your local tool warehouse or off the tool truck. No way around it. Also get a locking extension for it along with a U-joint and another extension.
Be very careful, you have aluminum heads. If you crossthread the plugs, you are screwed.
If you have the above tools, changing the plugs takes only about 45 minutes.
Hope this helps. Be careful.
George (20k miles to go on current plugs!)
Old Sep 19, 2002 | 09:06 PM
dtilden's Avatar
dtilden
Aren't the plugs different for 4 of the cylinders than tey are for the other 4? Check it out!
Re-elect Al Gore!
Old Sep 19, 2002 | 09:30 PM
PaulC's Avatar
PaulC
I believe Ford spec'd different plug numbers for each cylinder bank as installed by the factory. However I seem to recall the owners manual indicating just one number for replacement plugs on either bank. Check your manual.
Old Sep 20, 2002 | 07:34 AM
ummduh's Avatar
ummduh
The reason for spec'ing different plugs on each side is from the DS system, Ford used single platinum plugs, one bank has the platinum on the elctrode, the other bank has it on the ground.. When replacing these, replace with double platinum plugs. Thats what you'd get by going to Ford and asking for replacment plugs.
Old Sep 20, 2002 | 12:26 PM
RHODCO's Avatar
RHODCO
[updated:LAST EDITED ON 20-Sep-02 AT 01:28 PM (EST)]I was wrong. It doesn't help to jack up the front end.
It does help to smear Vasoline all over your arms and elbows when going after the #4 and #8 plugs. You feel like a snake trying to slither back in there. Vasoline just makes cleanup easier afterwards.
It's a very dirty job, especially if you're replacing the wires at the same time.
I had to remove the air cleaner assembly and the cruise control cable bracket in order to get to the plugs on the driver side.
Also, do it with the engine COLD. Much easier on your forearms.
I used Autolite Double Platinum APP104, NOT the APP764.(long story)
Old Sep 20, 2002 | 09:46 PM
Doorgunner808's Avatar
Doorgunner808
scslee29680
Mar 5, 2005 04:53 PM
johnfretz
Modular V8 (4.6L, 5.4L)
Aug 5, 2004 09:43 PM
Skywalker1980
Jan 23, 2004 04:08 PM
blacklightningf150
Dec 1, 2002 08:58 PM
