Where is the ECM code located?
Old Jun 4, 2007 | 01:39 PM
viperbluelx's Avatar
viperbluelx
I've gotta get my SCT Xcal2 fixed by SCT and they need the computer code? Where is it and how do I go about getting to it?
Old Jun 4, 2007 | 03:03 PM
Izzy351's Avatar
Izzy351
I'm assuming you're talking about your PCM -- the PCM is located in a plastic bracket by the parking brake pedal. You can read it with an inspection mirror & flashlight or pull it out. There are instructions around (and even a video) on the web about how to do it, but all you do is unscrew the 10mm bolt in the engine compartment & unplug the wiring harness (MAKE SURE YOUR KEY IS NOT IN THE IGNITION!), take out the two 7mm screws holding the braket & PCM in truck, and wiggle it out. Takes about 5 minutes. The sticker is on the end and is 3 letters & a number. Mine was "VDH2".
Joe
Old Jun 4, 2007 | 03:32 PM
ron's power stroke's Avatar
ron's power stroke
this is for a DP tuner..but it gets you where you want to be..good luck...may I suggest gauges be for you fry something
http://www.itpdiesel.com/other/DP-Tu...stallation.pdf
Old Jun 4, 2007 | 05:16 PM
Izzy351's Avatar
Izzy351
Here's the link to the video, if it helps...
http://www.dieselmovies.com/view_vid...163467c9dae521
Old Jun 4, 2007 | 05:19 PM
ron's power stroke
[QUOTE=Izzy351]Here's the link to the video, if it helps...
http://www.dieselmovies.com/view_video.php?viewkey=b0395e163467c9dae521[/QUOTE]
mine did the same as yours..i tryed to post that but it wont open any more..or is it my puter??
Old Jun 4, 2007 | 05:26 PM
viperbluelx
video doesn't work
Old Jun 4, 2007 | 05:27 PM
Izzy351's Avatar
Izzy351
Hey, you're right. Must be broken! I just looked at the video like a week ago...
Keep trying, though -- maybe it'll be okay after a while.
Old Jun 4, 2007 | 05:33 PM
ron's power stroke
thats to bad too..it was a good clip.i saved it to favorites last week too..i got from a another thread..
Old Jun 4, 2007 | 06:52 PM
Uzumati's Avatar
Uzumati
Give it a few hours, it looks like they are having DNS issues
