PCV Valve
Old Jun 4, 2007 | 09:10 AM
WiseMagic's Avatar
WiseMagic
PCV Valve
2000 EXP, 4.6 L Engine.
Isn't the PCV Valve on the right side of the engine near the oil dipstick. Has a small hose running from it knid of like a sparg plug wire cover?
To replace, do you just undo the hose and pull it out of the cover with some pliars and pop the new one in or is there more to it?
Old Jun 4, 2007 | 09:54 AM
buzzard's Avatar
buzzard
Yep, pretty simple procedure. Pull the old PCV from valve cover, disconnect hose and then reverse process.
RAGaz's Avatar
RAGaz
You got it. I have never even needed pliers - usually just comes out by hand.
Old Jun 4, 2007 | 07:48 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
Sometimes the hose and/or the grommet will get hard and brittle making it a little hard to get the sucker out, but keep working at it.
If you damage the hose, you can use an old plug wire elbow in its place, just make sure you inspect if often as those plug wire elbows will eventually absorb oil and swell up.
Good luck.
Mr Hanky
Modular V10 (6.8l)
Nov 7, 2010 01:35 AM
biz4two
Modular V10 (6.8l)
Oct 28, 2006 11:36 PM
hellraiser
Jul 19, 2004 07:13 PM
wsbenge
Sep 14, 2003 02:49 AM
BrianJ77
Aug 15, 2003 09:45 PM
