Sponsored by: Real Truck
01 psd engine problem
Old Jun 3, 2007 | 08:05 PM
crbav8r's Avatar
crbav8r
Driving 30mph slight downgrade with foot off the throttle and the truck died. It will not crank back at all. Mechanic said he thought it might be the cam-shaft position sensor, but said it would crank back after it cooled down... it did not. Help please
C. Brown
2001 F350 CC DOOLEY 4x4
Old Jun 3, 2007 | 08:28 PM
TNT in Round Rock's Avatar
TNT in Round Rock
try this down in the 7.3 forum .. will prob get more detailed responses there. Sounds like CPS to me as well. When you turn the key on, and turn the engine over, does the tach move ?
Old Jun 3, 2007 | 08:32 PM
crbav8r's Avatar
crbav8r
good question, I'll try that in the am.
thanks
Old Jun 4, 2007 | 12:51 AM
wlihntr's Avatar
wlihntr
the engine being cool or not has nothing to do with a failing CPS. it will just go dead at any time cold or hot...
Old Jun 4, 2007 | 01:14 AM
aldridgec's Avatar
aldridgec
Often it will show code p0341 for intermittent cam signal. If that is there and it's not starting that is about all it can be! Has been 100% of the time for me!
Old Jun 4, 2007 | 08:19 PM
crbav8r's Avatar
crbav8r
replaced the cps today... nothing. The tach does move when I crank the truck, and oil pressure also comes up. I removed the superchip program..still nothing. checked fuses...nothing. Anybody got anything else?
Old Jun 4, 2007 | 08:29 PM
MobeyDick's Avatar
MobeyDick
How many miles. It could be the HPOP.
Old Jun 4, 2007 | 08:39 PM
crbav8r's Avatar
crbav8r
170,000.. what is the hpop?
Old Jun 4, 2007 | 09:04 PM
MobeyDick's Avatar
MobeyDick
It's the box in front of the Fuel filter!! If it goes bad it will not start!
